  1. #10
    Hi All
    Today I tested the software using a 640 x 480 VGA webcam without a lens and #2 Roslau Music wire (0.0010" thick).
    Digging around the workshop I resurrected an accurate XYZ jig table I lashed up with some star linear bearings and preloaded 8mm screws some time ago, this enabled me to precisely position the webcam now stripped from it plastic housing and mounted on in an aluminium bracket securely clamped on the XY stage of the jig. Measurements were taken with a Mitutoyo 0.01mm per division dial indicator.
    The wire was positioned about .0015" above the face of the Camera sensor.
    Calculated resolution achieved was 130 lines used to measure 0.05m = .003846mm per pixel line 0.000151") see Excel Image below.
    This was repeatable I performed the test several times. however there are some issues measuring small values. It was difficult to measure .01 increments repeatably due to the software constantly recalculating very slightly different values. the source of this error needs to be tracked down. It may not be a software issue, I suspect It may be a combination of hardware and software issues.
    From various tests I have observed changing light conditions cause the measured value to change in a very substantial way. I also observed this using the laser in earlier tests although to a lesser extent.
    In the image below notice the paper tent covering the sensor this is essential to reduce the effect of stray light while providing somewhat even illumination of the sensor. It is not Ideal. I need to enclose the sensor in total darkness apart from an even illumination source behind the wire. I think this light source needs to be variable intensity to provide the correct grey scale balance for the software.
    Once the correct lighting conditions are achieved I will run the tests again.
    The tests today have proved that the Webcam software is already capable of very good repeatable accuracy. and that there is still plenty of room for improvement. Very exciting!
    Regards
    John
    4 images below:
Name:	Calc 1-09-2019 5-45-32 PM.jpg
Name:	1-09-2019 4-51-41 PM.jpg
Name:	1-09-2019 4-53-18 PM.jpg
Name:	1-09-2019 4-54-14 PM.jpg
Name:	Calc 1-09-2019 5-04-05 PM.jpg
  2. The Following User Says Thank You to John McNamara For This Useful Post:
  1. WANTED: K40 laser
    By dfox1787 in forum Items Wanted
    Last Post: 23-10-2018, 08:34 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. help with cnc laser
    By swinds in forum Laser Machines & Building
    Last Post: 09-01-2012, 10:15 PM
