02-09-2019 #11
Hi Joe
The measuring system is just a manually driven XYZ platform
Once set up I only move the webcam The light is at this time fixed and non moving. This is wrong! it should move with the webcam sensor although a 0.25mm movement is pretty small slightly less than 0.010 inches. I am going to work on the light next.
And yes I clicked measure after each movement to the next tick on the dial indicator. The straight line is proof that the system is linear. Subject to my possible manual positioning errors as detailed in my previous post.
And the results we are getting are better and better, once the lighting is sorted I am certain the repeatable accuracy can be improved. Once this is done I really want to try a higher resolution webcam.
Regards
John
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
