17-10-2019 #10
Hi Sasquatch
If you study the two test series I did with two different sensors you will see that the resolved measurements taken with the second sensor were better with the higher density (The pixel lines were closer together), sensor used for the second set of tests.
No lens was used just the wire shadow.
Devmonkey mentioned that the results were better without a lens when he did tests with a laser. Using a lens with the laser generated distortion? I can also confirm this when I tried using a laser with a lens.
Maybe the standard lens supplied with a webcam or action cam is not the ideal for working with a laser. I know industrial laser cutters use lenses made from Germanium and other exotic materials.
A friend who spent his working life as a physics lab tech also mentioned that webcams will probably have a red filter behind the lens and in front of the sensor. He suggested that this should be removed if working with laser light.
These are only study notes on my part, I wish I knew more about optics. Maybe one of the MYCNCUK members here can give a more qualified view?
Regards
John
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
