    It's cheap Sj4000 clone distortion is massive, if there is correction it does very bad job. I have cheap webcam and 0.08mm steel wire on order. Will try both laser and wire to rule out sensor nonlinearity errors.
    Quote Originally Posted by Sasquatch View Post
    One other thing that occurred to me, how did you ensure you moved the sensor/vice assembly absolutely in a straight line? Any deviation in this procedure would show up as non-linear errors in your linearity measure since it would have been impossible to get the laser perfectly planar with the granite. This applies to both types of laser dot and line. I think you need a precision straight edge as well as the reference surface to check the accuracy of the system.
    Quote Originally Posted by devmonkey View Post
    I used straight edge clamped to the granite, just as you said.
    Cheap webcam arrived, useless with lasers, sensor is smaller than the beam, will test it with wire when it gets here.
    Sounds like your laser is no good, can you post a picture of it? Even my dewalt laser level produces a line narrower than the VGA sensor.
  1. WANTED: K40 laser
    By dfox1787 in forum Items Wanted
    Last Post: 23-10-2018, 08:34 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. help with cnc laser
    By swinds in forum Laser Machines & Building
    Last Post: 09-01-2012, 10:15 PM
