    Hi Joe
    The mirrored face prism has 6 sides
    It is driven by small three phase board mounted disk motor and a Toshiba TC9242P Motor driver chip.
    For a quick test I tried using a small laser pointer and spinning it by hand got a nice bright red line. Very sharp if the target was a short distance away however as suspected on first observation the beam focusing lenses as used by the HP printer were set for a short distance. The dot increased in size quickly as you moved the target away.
    However the rotating mirror prism without the lenses worked well, I just spun it by hand for a quick test of the concept.
    I will have to do a proper test once I sort out the interface. The laser diode I used was a cheap giveaway pointer!
    I removed the invisible light diode as fitted by HP for safety, just two screws and it leaves a nice mounting face for the replacement visible red diode. For this test I just held it by hand....
    Just read your post 161
    The line is generated by the changing face angle, with 6 faces I am guessing the line generated will be about 60 degrees assuming 360/60 is the correct formula? The HP laser unit itself has a coverage of about 60 degrees.
    Mechanical errors?
    As I see it the rotating prism mirror presents every side to the laser in turn. The line generated should be straight if the laser is located perpendicular to the axis of rotation. if not on axis a slightly curved line would be generated.
    The bearings of the rotating spindle may not be perfect, this may cause the edge of the optical plane generated to wobble up and down for each rotation turn? However your software makes multiple measurements and averages them, This should help cancel out this error.
    Regards
    John
    Quote Originally Posted by John McNamara View Post
    Hi Joe
    Regards
    John
    Hi John,
    A penta-prism doesn't suffer this problem, it has two faces at 90 degrees, then two other faces at 90+22.5 to the first two, the fifth face is not relevant, some might not even have it or maybe have multiple. Good picture on wikipedia.
  1. WANTED: K40 laser
    By dfox1787 in forum Items Wanted
    Last Post: 23-10-2018, 08:34 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. FOR SALE: K40 laser not working (laser fires)
    By calida in forum Items For Sale
    Last Post: 31-03-2015, 08:45 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. help with cnc laser
    By swinds in forum Laser Machines & Building
    Last Post: 09-01-2012, 10:15 PM
