21-02-2020 #11
Hi Joe (Devmonkey)
Hi All
Firstly I am assuming profiled rails are being used not round rail for high accuracy, repeatability and negligible backlash.
Lateral adjustment of rails is difficult, particularly when you take into account the small amount of adjustment allowed by the clearance around the mounting screw in the bored hole in the linear rails. for type 25 rails typically a 6mm hole and a 5mm machine screw. This only allows +- 0.5 mm of lateral adjustment, and this is if all the mounting holes are perfectly placed. Note in the description the order of processing to minimise chips creeping into the joining surface and lifting the rail.
To solve this problem I devised method where the rails were positioned laterally first using cams. Once this was done I drilled and tapped the mounting holes using an inexpensively built jig. You can make the cams yourself or get them laser cut. You still have to countersink them as detailed in the link.
It is documented here:
https://www.model-engineer.co.uk/for....asp?th=139042
The method worked very well. Alas I have not completed the machine.
I can't wait to get back to it! Alas work has been getting in my way too.
Regards
John
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
