    Maybe you got confused with all the chatter of 10k internal resistors, pull-up resistors and so on. You paid good money for a quality controller and therefore the prox sensors just plug straight in !
    I think I used resistors on the 12V front panel LEDs to run off 24V but that depends on how, or if , you want indicator lights for status and so on. For example they can also be mains powered indicator lights.
    Sorry guys, fuses, not resistors! Theres a lot on my mind right now...
    However, havent got to it yet, collecting the final parts right now but, i read about one resistor in the driver manual.
    Remark:
    VCC is compatible with 5V or 24V;
    R(3~5K) must be connected to control signal terminal.
    If im not mistaken i think i read about it in in the Csmio manual also but they recommend a 2K resistor there!?
    Couple of odd comments:
    IP/M is very happy with direct connection of prox switches running on 24V. Works well.
    IP/M drives the usual stepper drivers directly without needing any resistors. Use differential connection if your drivers support this - better noise resistance.
    Unlike Jazz, I've not been too lucky with prox switches from eBay. I bought a box of ten. One was the wrong type (unbelievable! Two-wire, quite obviously not the same as the rest of the 3-wire switches), one was faulty straight from the box, and one failed very shortly after fitting. However, the rest have been working fine for a couple of years now, and the whole box probably cost less than one "professional" quality switch. That's the difference between home building and commercial - commercial machine could not stand that level of quality, but it suits my pocket!
  4. The Following User Says Thank You to Neale For This Useful Post:
  5. #4
    I too bought a box of 10 from China.
    The machine I have from MD had end-on axial sensing and I crushed a sensor whilst jogging (the machine, not me!), In my naivety I ordered a replacement from MD and it cost £17.50 (ouch, ouch,ouch). When I crushed that one, I ordered 10 from China and converted the sensing to bypass.Some have orange sensor ends and a grey cable and some have blue ends and a black cable. I have 9 of them left. They are all NO and 4mm.
    Cheers,
    Rob-T
  6. #5
    I also have had about 30 from AliExpress with no duds with pnp and npn types.
  7. #6
    My chicom mechanical switches are quite reliable, omron copies.
    They are not too accurate, and the mechanical assys are terrible, in terms of machinist parts.
    0.01-02 mm +/- in repeatability/accuracy is terrible.
    For my cnc lathe, industrial quality.
    But for routers, they are much more than good enough.
    (My lathe is for sub-micron or 1 micron repeatability.)
    Cheap 5$ optical limit switches provide about 2 microns accuracy, fairly easily.
  1. G540, homing switches and mach3
    By marbles in forum Artsoft Mach (3 & 4)
    Last Post: 02-06-2018, 02:55 PM
  2. Problem with homing
    By Andyman in forum Gantry/Router Machines & Building
    Last Post: 22-03-2016, 07:56 PM
  3. Homing switches & 'methods of working' (Mach3)
    By HankMcSpank in forum Artsoft Mach (3 & 4)
    Last Post: 19-10-2012, 12:54 AM
  4. Homing Switches
    By m_c in forum General Electronics
    Last Post: 04-11-2010, 11:21 PM
  5. A simple query about homing switches & milling practise
    Last Post: 13-06-2009, 11:56 PM
