15-08-2019 #1
Spindle Motor Specifications :
Power : 5.5KW
Voltage : 220V ( option 380V)
Current : 15A
Frequency : RATE 400Hz max 600hz
Speed : 18000rpm max
Cooling Type : Water-cooled
Joint of nose : BT30 Taper
Lubrication : Grease
weigth: 26kg
Diameter: 125mm
Lengt: 460mm
Air pressure: 6kg/cm2
4 Bearing, 7008x2 7006x2, all ceramic p4 china brand
The price inclue spinde 5.5kw (normal is 220V, 380V option) + spindle holder 125mm + 6 pcs holder NBT30 + 6 pcs collect ER 3mm, 4mm, 6mm, 8mm, 10mm, 12mm + Airtac 24V solenoid + Airtac air regulator + sunfa E550 5.5kw VFD
contact
[email protected]
whatsapp +8490330934
https://www.ebay.com/itm/183899631699
custom Turbo Dust Shoe for your spindle and hose size combo
By Boyan Silyavski in forum Manufacturer NewsReplies: 12Last Post: 09-04-2020, 09:09 AM -
FOR SALE: Combo ATC spindle BT30 3kw rate 220V/400hz max 600hz 18000rpm+ holder NBT30 + 4kw VFD
By nhatson in forum Items For SaleReplies: 0Last Post: 07-08-2019, 04:09 AM -
BT30 Ebay spindle
By pnub93 in forum General DiscussionReplies: 4Last Post: 16-01-2019, 04:05 PM -
BT30 in an R8 spindle?
By Ross77 in forum Tool & Tooling TechnologyReplies: 6Last Post: 07-07-2018, 08:51 AM -
Connecting power supply for 220v
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 08:34 PM
