Page 7 of 7 FirstFirst ... 567
    Quote Originally Posted by IhateDoug View Post
    Also noticed these
ID:	26338Click image for larger version.
    If they aren't modifications made since it last worked then they should be ignored as it ran fine like that previously?
    It's not uncommon for manufacturers to correct a faux-pas on a board with a wire link ;-)
    Seems it’s the breakout board - I bought a cheap one + new drivers - Am having trouble wiring it however there is life, spindle comes on when powered (can’t turn off, can control the speed via the inverter and that’s it and z axis moves up (both keys make it go up), the limit switches are now showing in the diagnostics page and if I home the machine it seems to move in all directions - Estop switch is broken and Will be replacing and the estop button in Mach3 doesn’t stop it - so I quickly pulled the power shortly after it started moving, but seems like it moved in all directions.
    How I wired it
    Raul's Avatar
    Lives in SANTANDER, Spain. Last Activity: 26-04-2021 Has been a member for 3-4 years. Has a total post count of 9.
    How I wired it
    Hi all, I am new with CNC, but I have try to get my CNC working but apparently if I don't have the conexions from the board os the picture to the drivers, it is impossible to make it work, So there is any has found the pins and dir conections that I can put on Mach3 to make my CNC from Marchant Dice Ltd. working? See pictures attach,
    Do I need to disassemble the box to find out how they are connected?Click image for larger version.
Name:	tarjeta CNC 1.jpg
ID:	29612Click image for larger version.
Name:	Tarjeta CNC 2.jpg
ID:	29613Click image for larger version.
Name:	Tarjeta CNC 3.jpg
    thank you very much in davance for your help, I am going crazy, I can not find any information about this card: Bazyx east crystal pcf 07343 five axis cnc board Rev. 1.4
    Raul's Avatar
    It looks like I have the old fashion card, but does anyone has the pins and dir conections for the step-motors fo the CNC machine from Marchant Dice Ltd. I can not make it work, and I can not find any information about it, only this post and the card doesn't look the same. Can you help me? see attach pictures Click image for larger version.
ID:	29615Click image for larger version.
ID:	29616Click image for larger version.
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. FOR SALE: For Sale Syil X7 plus CNC Milling machine
    By dpcwright in forum Items For Sale
    Last Post: 13-09-2015, 02:27 PM
  3. Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
    By towdi.arek in forum Marketplace Discussion
    Last Post: 20-07-2013, 07:26 AM
  4. What i am doing wrong with mach3?? trying to config machine.
    By scnc in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 05:01 AM
  5. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
