    Quote Originally Posted by IhateDoug View Post
ID:	26337Click image for larger version.
ID:	26336Click image for larger version.
ID:	26335Click image for larger version.
ID:	26334Click image for larger version.
ID:	26333Click image for larger version.
ID:	26332Click image for larger version.
ID:	26331Click image for larger version.
    Ok nowhere do I see a Parallel port cable but I do see an Ethernet Cable going to what looks like a Controller board with ribbon cables going to Breakout board so are you sure it's using Parallel port.?
    If it's using Ethernet then it won't work untill you set the Ethernet address and it would be Dead just like your experiencing.!
    Now I have seen the pics, I get the bigger picture. The QTCL BoB is a parallel port BoB - BUT - in this case it is being driven by the PCF08094 which is an ethernet interface.
    You have two options :-
    Set up the Ethernet address as Jazz says (which is the better way to go!)
    or plug the QTCL BoB into your printer port with an appropriate printer cable adapter like this one - If you could find one (I am not selling mine!)
    The printer port connects to the PCF08094 board - which then connects to the Bob via a ribbon cable ( This is how it was when I bought it and worked).
    So are you saying to unplug the ribbon cable that currently connects the print port to the PCF08094 board and connect it directly to the bob?
    I have uploaded a video which mite make things clearer
    One of the ribbon cables connects to the parallel port. The Ethernet cable runs to the control panel on the front of the machine - the board the Ethernet cable comes from is
    PCF08094 DS0809
    EAST CRYSTAL Rev:1.0
    And the one below it which connects to the parallel port is
    PCF 07483
    EAST CRYSTAL Rev1.1
    Ds0807
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. FOR SALE: For Sale Syil X7 plus CNC Milling machine
    By dpcwright in forum Items For Sale
    Last Post: 13-09-2015, 02:27 PM
  3. Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
    By towdi.arek in forum Marketplace Discussion
    Last Post: 20-07-2013, 07:26 AM
  4. What i am doing wrong with mach3?? trying to config machine.
    By scnc in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 05:01 AM
  5. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
