24-08-2019 #11
So, my thoughts are - with the other end of the cable plugged into the computer(?) that any output on pin 17 (the X-Direction pin) will be driving the E-Stop input into Mach3. By moving the X-Axis one way you'll set the X-Dir pin to +5V, by moving the other direction you'll set the X-Dir pin to 0V. You might have to do this from the "Run" page/tab on Mach 3... then head to the diagnostic page to witness the setting of the pin-11 input (estop). Sounds obvious, but with moving the axis in one direction, pin 11 input should be active, and in the other direction pin 11 should be in-active. This is just intended to verify the behaviour of the PC/motherboard, and later to verify the binding of the pin to the e-stop input.
syil x4
By geoff in forum Machine DiscussionReplies: 8Last Post: 30-11-2016, 07:35 PM -
FOR SALE: For Sale Syil X7 plus CNC Milling machine
By dpcwright in forum Items For SaleReplies: 1Last Post: 13-09-2015, 02:27 PM -
Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
By towdi.arek in forum Marketplace DiscussionReplies: 3Last Post: 20-07-2013, 07:26 AM -
What i am doing wrong with mach3?? trying to config machine.
By scnc in forum Artsoft Mach (3 & 4)Replies: 39Last Post: 31-01-2013, 05:01 AM -
thinking about this Syil X5plus CNC Milling Machine with 4th Axis
By Dellboy in forum Marketplace DiscussionReplies: 8Last Post: 22-04-2012, 05:52 PM
