That board is the spindle board. The connector is the enable and is being used to signal E-stop occured. The pins could just be jumped and it would work.
If your 100% sure BOB is getting signals then start by making sure power is getting to the Bob.
The schematic shows that the E-stop controls a relay which provides 12v to power the BOB and the spindle board. The E-stop on the BOB is just shorted to Gnd and isn't actually used thru a E-Stop button.
This is a simple BOB and should work if provided with power and signals. Nothing else external controls it's functions ie: enable, charge pump etc.
If its getting power/signals and your pin settings are correct then it will work. So if it's not then call it dead and move on.
Sent from my SM-T580 using Tapatalk-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
syil x4
By geoff in forum Machine DiscussionReplies: 8Last Post: 30-11-2016, 07:35 PM -
FOR SALE: For Sale Syil X7 plus CNC Milling machine
By dpcwright in forum Items For SaleReplies: 1Last Post: 13-09-2015, 02:27 PM -
Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
By towdi.arek in forum Marketplace DiscussionReplies: 3Last Post: 20-07-2013, 07:26 AM -
What i am doing wrong with mach3?? trying to config machine.
By scnc in forum Artsoft Mach (3 & 4)Replies: 39Last Post: 31-01-2013, 05:01 AM -
thinking about this Syil X5plus CNC Milling Machine with 4th Axis
By Dellboy in forum Marketplace DiscussionReplies: 8Last Post: 22-04-2012, 05:52 PM
