Out of interest is the diode in series with the supply - I.e. prevent reverse connection? Or is it across the coil -I.e. fly back protection when switching. If across the coil maybe it will stress the power supply if bypassed ?
19-08-2019 #2
The only info I have is from the sketchy diagram in the data sheet. I think the idea is that you can see how it works (5 relays, apparently, with all sorts of interconnections) but without much detail - there's a lot more in there than they show! However, the diode is shown as being in series with the supply, together with a resistor (no value given). I'm guessing protection against a short to another supply in the external e-stop circuit (diode) or short to earth (current-limiting resistor). I would guess that in my case the diode has gone pop (never trust a semiconductor) but it might just be a broken track. No back-emf diodes shown, although they might be there somewhere. I have another 24V relay in the box, driven from the 24V SMPS, with no diode involved. I don't know what kind of back emf could be generated but these aren't high-current relays anyway.
If this hadn't worked, I was considering making my own poor-man's version. Take the usual latching relay type of setup, with a momentary n/o switch to enable. Put a second relay in parallel, and wire NC contacts in parallel and NO contacts in series. That should cover you against either relay failing to operate or sticking on.
I run e-stop switches plus fault outputs from the stepper drivers through the e-stop input on the safety relay although limit switches just go to the motion controller. The safety relay will enable/disable the motion controller, the stepper drivers via the enable inputs, and the stepper PSU via another relay.Last edited by Neale; 19-08-2019 at 07:42 PM.
Proximity wiring for limit switches, safety relay and a contactor
By CharlieRam in forum General ElectronicsReplies: 15Last Post: 02-06-2019, 11:18 PM -
Schematic question wiring Am882 ALM Alarm, Limits and Security Relay Pilz S5 ?
By pierantoine in forum General ElectronicsReplies: 6Last Post: 01-05-2019, 02:32 PM -
Pilz Relay info
By manofgresley in forum General ElectronicsReplies: 5Last Post: 08-05-2014, 10:16 PM -
Info on Chinese suppliers, their reliability and reputation
By Want2build1 in forum Marketplace DiscussionReplies: 38Last Post: 07-12-2013, 09:37 PM -
DIY CNC Safety Guide
By tati in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-08-2013, 12:02 PM
