    The only info I have is from the sketchy diagram in the data sheet. I think the idea is that you can see how it works (5 relays, apparently, with all sorts of interconnections) but without much detail - there's a lot more in there than they show! However, the diode is shown as being in series with the supply, together with a resistor (no value given). I'm guessing protection against a short to another supply in the external e-stop circuit (diode) or short to earth (current-limiting resistor). I would guess that in my case the diode has gone pop (never trust a semiconductor) but it might just be a broken track. No back-emf diodes shown, although they might be there somewhere. I have another 24V relay in the box, driven from the 24V SMPS, with no diode involved. I don't know what kind of back emf could be generated but these aren't high-current relays anyway.
    If this hadn't worked, I was considering making my own poor-man's version. Take the usual latching relay type of setup, with a momentary n/o switch to enable. Put a second relay in parallel, and wire NC contacts in parallel and NO contacts in series. That should cover you against either relay failing to operate or sticking on.
    I run e-stop switches plus fault outputs from the stepper drivers through the e-stop input on the safety relay although limit switches just go to the motion controller. The safety relay will enable/disable the motion controller, the stepper drivers via the enable inputs, and the stepper PSU via another relay.
  1. Proximity wiring for limit switches, safety relay and a contactor
    By CharlieRam in forum General Electronics
    Last Post: 02-06-2019, 11:18 PM
  2. Replies: 6
    Last Post: 01-05-2019, 02:32 PM
  3. Pilz Relay info
    Last Post: 08-05-2014, 10:16 PM
  4. Info on Chinese suppliers, their reliability and reputation
    By Want2build1 in forum Marketplace Discussion
    Last Post: 07-12-2013, 09:37 PM
  5. DIY CNC Safety Guide
    By tati in forum Gantry/Router Machines & Building
    Last Post: 12-08-2013, 12:02 PM
