    Chaz's Avatar
    I'm looking at a screenshot of the General settings page, I dont see it. Any idea where it is?
    https://www.machsupport.com/wp-conte...all_Config.pdf - page 5-35 is the General Settings Page.
    I use Mach3 and an IP/M on my router and have never noticed any jerkiness on curves. Don't know if that is luck or the right settings! I've been using F360 with various cutting strategies recently, some of which use a large number of short straight line segments which Mach3 seems to handle ok. So it seems ok whether or not G2/3 or straight line segments are used. I am using steppers rather than servos and it does seem possible that servo tuning would have an effect here.
    Chaz's Avatar
    Thanks. I have no issues with straight lines, its when arcs / circles are involved.
    I was thinking of the case where F360 is approximating non-circular curves (e.g. adaptive clearing strategies) using many very short straight line segments so there are a lot of rapid direction changes. Mach3 is supposed to smooth these, as I understand it. This kind of tool path is bad news if Mach3 is configured to "exact stop" mode but in constant velocity mode it's fine.
    On reflection, though, probably not very relevant as you are using analogue servo controls which introduces a whole bunch of other variables. Good luck!
    Chaz's Avatar
    Yep and the same code runs without an issue on Centroid.
    Have a look at 5.6.6.2, I/J Mode: You can set the interpretation to be placed on I & J in arc moves. This is provided for compatibility
    with different CAM post-processors and to emulate other machine controllers. In Inc IJ
    mode, I and J (the center point) are interpreted as relative to the starting point of a center format arc.
    This is compatible with NIST EMC. In Absolute IJ mode, I and J are the coordinates of the center in
    the current coordinate system (i.e. after application of work, tool and G92 offsets). If circles always
    fail to display or to cut properly (especially obvious by them being too big if they are far from the origin),
    then the IJ mode is not compatible with your part program. An error in this setting is the most
    frequent cause of questions from users when trying to cut circles.
    Phill
  7. The Following User Says Thank You to phill05 For This Useful Post:
  8. #7
    Chaz's Avatar
    Phill
    Thanks. Ive messed with this before. Normally when its wrong, it doesnt cut the right tool path at all. I dont think that's the issue here.
  9. #8
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok there is a setting on that page radio button "motion mode" it should be on constant vel. I think there is a light on the main screen that should go green when G64 is on in the code. If G61 is in the code that will cause the stopping
  1. cs-labs.eu website problems
    By chillybo in forum CS-Lab (CSMIO)
    Last Post: 15-04-2019, 05:42 PM
  2. FOR SALE: Cs labs csmio ip-s
    Last Post: 22-07-2018, 08:45 PM
  3. Replies: 10
    Last Post: 28-08-2017, 10:15 PM
  4. Denford Orac and CS Labs controller
    By swdiver in forum Denford Lathes
    Last Post: 07-08-2017, 10:59 PM
  5. FOR SALE: PSU Rectifier + Capacitor smoothing board for toroidal transformer
    By Jonathan in forum Items For Sale
    Last Post: 02-02-2017, 10:47 PM
