27-08-2019 #3
Hi Kit
Thanks for your input. I've been racking my brain trying to work out how to get the open-collector transistors to send 5V to the Base on the transistor required to power the Step signal on the milling machine driver. I've drawn out 2 circuits, the first it the one I have already tried and it failed, but when I connected the 2K resistor directly to the 5V source on the breakout board, rather than the X step output (Pin 2) it did cause the X axis to step once. The second circuit is my version 2, do you think this would work?
I'm open to any suggestions, all I need to do is connect the X Axis step signal input on the milling machine to ground and I need the pulses from the BOB to make and break that connection.
Dan.
complete conversion kit for AMA25LV
By Fatoftheland in forum Milling Machines, Builds & ConversionsReplies: 31Last Post: 10-04-2021, 04:31 PM -
Denford Triac VMC w/ ATC conversion
By stallone in forum Milling Machines, Builds & ConversionsReplies: 27Last Post: 08-12-2015, 10:26 AM -
Needing advice on linear rail blocks
By oldmam4m80s in forum Rails, Guideways & BearingsReplies: 0Last Post: 27-10-2013, 07:57 AM -
NEW MEMBER: Complete Beginner requiring advice!
By Robduffer in forum New Member IntroductionsReplies: 13Last Post: 07-05-2013, 04:17 PM -
Complete conversion kits?
By leitzscope in forum General DiscussionReplies: 3Last Post: 01-05-2010, 07:57 PM
