I would use a single piece of 5 or 6mm but if you already have the 2 mm plate then triple it up.
I would do both - the 10mm plate to act as the sub base to be tapped into for fixtures etc. then add the 40mm sections underneath ensuring they are joined to each other.. Adding another skin under the 40mm sections (even 2mm steel would be good) to make a sandwich.
But it won’t count for much unless you can tie the base to the sides. Do you need open access both ends ? Can one end be full height shear panel joining both sides and the base ? Or can the corners be triangulated at least rather than squared off as drawn.
MicroRouter Spindle upgrade - advice and help required
By ngwagwa in forum Spindles & Drive MotorsReplies: 16Last Post: 26-05-2019, 02:52 PM -
Rigidity of aluminium profiles and rectangular tube sections....
By Voicecoil in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 14-10-2018, 01:51 PM -
profile rail and purchase advice
By johngoodrich in forum Marketplace DiscussionReplies: 2Last Post: 17-09-2016, 07:53 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
