    Hello
    IM normally quiet smart but the following has me stumped. My Carpentry brain just cant work it out
    I have a machine that has a 200x 20mm sliding plate ( slides on 2 SGB20N bearings each end) it has a vertical load of 400N each side
    I need to get this plate to slide(powered) from one end of the rail to the other (900MM)
    I think maybe a 16mm Ballscrew driven by a 12vdc ( it is to fit inside a car ) reduction right angle worm drive gearbox (3000rmp 30 watt motor)
    if this has and encoder i could set the limits . it must travel both ways)
    the overall speed of the plate is 0.045m/sec ( 20 secs to travel the 900mm so its not fast)
    im not sure what type of ballscrew 1604-1605-1610 ? would be best ( question 1)
    then i need to know the output rpm of the gearbox and the torque required to move the plate easily ( question 2)
    a suitable model no of motor-encoder-and gearbox ( Question 3)
    Im not even sure IF this type of system will actually work. I thought of a rack and pinion setup but i dont have the space or know how for this either.
    The ballscrew would be mounted on the side wall of the machine with standard BF/BK bearings and the Ball nut and housing secured down to the top of the plate.
    Ive googled and found a million calculations but i just cant work this out
    Any help hugely appreciated. If thi
    Attached Thumbnails Attached Thumbnails ballscrew pdf.pdf
  2. What screw did you use to work out it would take 20 secs to travel 900mm ? The 04, 05 and 10 in the version numbers stands for the thread pitch of the screw, so 1 full rotation of the screw would make anything connected to the screw's lead nut move 10mm and so on.
    I would find a reduction gearbox first and then go from there, once you've got that sorted out you can then look to a suitable motor. I would probably think about a smaller screw as well, its hard to know what direction to go in as you haven't given us much info on what the intended purpose of the machine is...
    Sound like it could be intresting...12v...only 4Nm to move...fit inside a car !?!?!
    .Me
    Hi Lee
    im using M16-10 coupled to a 120 W , 2200 rmp thru a 1:75 box (finished speed 293+-) torque 3.21 NM ..293 x .01 = 2.93m / 60 = .0488 x 20 sec =976mm
    ( I hope i got it all correct )
    Putting it all thru a uniquegoods 12-30V MAX 30A DC Motor Speed Control with Wireless Remote Controller Adjustable Switch Reversible Driver Governor Two Way Version + Limit Function with 2 proximity sensors ( one each end of travel) which changes direction of screw.
    I have to sort the wiring out and how to control it all ( 6 button Linear actuactor controller perhaps )
    the whole machine slides on SGR 20 tracks with a pair SGB20N bearings each end. It litterally takes a gentle hand push to move from one end to the other.
    My Brain has had a bloody good workout but still not really up on the electrics stc.
    Had help from other forums to get me this far.
    The machine is a "thing of beauty " .. At least i think so :0)
    Thanks for your interest
    Richard
    Hi RJSutton
    I have been thinking on your project and considering a timing belt driven linear motion instead of a ball screw drive, this will simplify construction, be more compact and be cleaner.
    Ballscrews need to be lubricated externally require bulky end support bearings and very accurate alignment between the ball nut attached to the moving member and the screw itself. Ball screws are not always self locking due to the low friction coefficient.
    A timing belt drive is run dry, It can work successfully with some misalignment and can use simple off the peg sealed bearing units bolted on to or using flanged or circlip bearings clamped into laser cut frame members. For a project like this laser cut sheet parts should be a primary objective, remember they can be press brake folded after cutting.
    You will be surprised at the load carrying capacity of a timing belt, the backing contains multiple strands of fine steel or kevlar.
    Timing belt drives are extensively used in industrial robotic applications.
    For reciprocating drives the belt can be purchased by cut to length, The two ends are attached to the moving member. Using a timing belt you would use a higher ratio worm reducer to achieve the same output speed.
    Beyond a certain ratio worm reducers are self locking an important consideration for a lift drive subjected to gravity.
    Below is a link to Gates among the world leaders in this field. Have a browse around the website you will find a lot of useful information..
    https://www.gates.com/us/en/resource...x-pro-software
    Regards
    John
    cheers John
    Thanks for the input
    Unfortunately this time im going to try the screw drive as ive purchased all the items already and waiting for delivery
    the ballscrew is only used to move the platform horizontally . you mention "subject to gravity" which makes me think you have a vertical usage.
    thanks Richard
    Hi RJ
    I assume the wheel chair has to slide out of the cargo space of the vehicle then be lowered down to the ground, in a way somewhat similar to the way a forklift works. In my head I imagined the chair parking on a plate that has channels for the wheels to locate them. When lowered to the ground the chair would be driven on to the plate and locked in place probably by clamping the wheels in some way. Once locked on, the plate would rise then slide into the cargo space with sufficient room for the cargo door to be closed.
    Regards
    John
  1. Design Help Pt2 Required for CNC design/Build
    Last Post: 21-07-2014, 02:05 PM
  2. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  3. Spindle torque required
    By m_c in forum Spindles & Drive Motors
    Last Post: 06-09-2012, 09:43 PM
  4. Replies: 0
    Last Post: 09-04-2012, 11:20 AM
