    Hi Virgin,
    Ok well first you say the machine is working so would guess you have some type of breakout board already.? If you are not sure then you need to take pictures of the control box so we can see what you have.
    There's a possibility you already have the ability to control spindle speed already as many Bob's provide 0-10v Analog output or PWM spindle output.
    Next thing is do you really need to set the Speed using Mach3 or will you be happy if Mach3 just turns spindle on/off. Mach doesn't need any external boards to control ON/OFF so easy to wire up.
    Post pics and we'll get you sorted.
    Here are the pictures, the first is the controller and the second is the VFD I want to control. There is a second parallel port on the computer so I was wanting to control the spindle through that.
    This is the machine and I am building a new enclosure for it.
    If it is any help, this is the controller board schematic:
Name:	Breakout Board-02.jpg
    Hi Virgin,
    Plain Vanilla 4-Axis control only with Home, Limit and E-Stop inputs using the PC's onboard PP (I added the 4th to the 3-axis box)
    The PC has a second PP.
    He wants to add On/Off/RPM control using the second PP.
    Right then, it appears I will need a couple of things. I will need a project box for all the bits. A parallel cable to run from the Computer to the Project box, this in turn will connect to the Break Out Board. The Break Out Board will send a signal to the Controller Board I have and as m_c has said above the Controller board itself will need a 24volt supply which I can incorporate into the project box.
    I spoke to Nick today about this and he also thought a relay might be required on the BOB if I want to control on/off of the spindle. So, all things being equal, does anyone have any suggestions as to which BOB I should buy? Ideally dual function because I could also use the board to turn the coolant on and off, maybe, perhaps? And will I need a power supply to the Break Out Board?
    Thanks in advance.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    In all honesty, I would probably say get one of the cheap 5-axis BOBs off ebay.
    They've got a relay output, and a 0-10V output, along with extra inputs and outputs.
    You'll need to wire in a 12-24VDC for the 0-10V output to work, and IIRC you need to connect the USB (or the 5V to the relevant terminals) to power the optos.
    Just search on eBay for "5 axis breakout", and you'll get plenty options.
    And you'll also need a straight through parallel cable to go with it (at least I think it's a straight through that you need, I've never actually used a parallel port for CNC!)
    Yep agree with M/C 100%, by far the easiest solution. Can forget messing around with that PWM board and using an external relay then.
    Well I have ordered a Break Out Board, an enclosure and a power supply for the +5v. More questions when it finally arrives.
    While I am at it, I was thinking about adding a handwheel to the setup to control the stepper motors as and when. Is it simply a matter of plugging this into a USB port on the computer? Or does this require me to start another thread? Better still, is there a thread already?
    Thanks everyone for your help so far.
    Quote Originally Posted by northwest View Post
    There are various pendants available for Mach3, most of which work via USB.
    Easiest option is to do a search on eBay for "Mach3 pendant", and you'll get a few different options.
    The cheap option is just to use a basic joystick/controller (xbox controllers are cheap, and IIRC there is a Mach3 plugin for using one). It all depends on how much money you want to spend.
  1. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
  2. Controlling the spindle RPM
    By D-man in forum Spindles & Drive Motors
    Last Post: 28-04-2016, 08:20 PM
  3. CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
    By andre13442 in forum Conversion Build Logs
    Last Post: 14-01-2016, 12:14 PM
  4. 800w spindle - noise & controlling remotely
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 17-10-2013, 06:26 PM
  5. PDA Controlling A Steeper Motor
    By ceaser in forum Stepper & Servo Motors
    Last Post: 23-05-2009, 03:03 PM
