30-08-2019 #2
It will depend on what is already in the mill.
Depending on if it has a motion controller and/or, there may already be a suitable analogue output for controlling spindle speed.
However, essentially that board needs a 24V power supply, and a step output (it claims PWM, but I'm pretty sure Mach3 using parallel port doesn't have any PWM outs, it's all step/dir). It then converts the step output to an analogue voltage, which is fed into the VFD.
The other option would be to use Modbus to control the VFD, but even for the IT/electronic literate, it can be a challenging option to implement.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Controlling the spindle RPM
By D-man in forum Spindles & Drive MotorsReplies: 16Last Post: 28-04-2016, 08:20 PM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
800w spindle - noise & controlling remotely
By HankMcSpank in forum Generic Chinese SpindlesReplies: 49Last Post: 17-10-2013, 06:26 PM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
