Page 2 of 2 FirstFirst 12
    Any connection between the bolt head and the chassis will result in a shorted turn
    but if its fitted in a low profile metal enclosure
    then it may be possible for the top to be deformed and touch the bolt head if pressure is applied !
Name:	Mount in metal enclosure.jpg
    John
    Quote Originally Posted by john swift View Post
    John
    How about the lower end? The nut will be in contact there right?
    the lower end is OK as the chassis , bolt and top mounting disk don't form a complete turn around the toroidal core
    its only when you close the loop by connecting the mounting disk to the chassis by a conductor outside the core
    John
    John
    Allright, thanks!
    When were at it, what type of fuses would you use for a PSU?
  5. #15
    Quote Originally Posted by JW1977 View Post
    Allright, thanks!
    For a toroidal transformer feeding a rectifier/smoothing capacitors you'll need a time delay (T) fuse as the switch on current surge can be VERY large.
    However if you have a fairly constant power drain you can reduce the surge by fitting a NTC thermistor in series
  6. #16
    Any idea what the transformers VA rating is ?
    As a toroidal transformer inrush current is very large
    I would not be supprised if you need a fuse 3 or 4 times what the VA rating would indicate
    if you have a 600VA transformer
    you may have to use a HRC 10A mains fuse (HRC = High Rupture Capacity)
    and check what type of circuit breaker is supplying the radial circuit your mains socket connected to
    for example
    a type B breaker trips at 3 to 5 times the full load current operating time 0.04 To 13 Sec
    a type C breaker trips at 5 to 10 times the full load current operating time 0.04 To 5 Sec
    John
    PS
    if the transformer is large enough you may have to consider using an inrush current limiter
    some examples here -
    https://sound-au.com/articles/inrush.htm
    PPS
    more details of a Soft-Start Circuit
    https://sound-au.com/project39.htm
  7. #17
    Allright, i have to keep looking into that...
  8. #18
    for example
    John
    PS
    PPS
    Yes, its 800VA. Got some Reading to do about this, thanks!
  1. Help me to choose transformer
    By Gytis in forum General Electronics
    Last Post: 06-07-2019, 10:46 AM
  2. Failed toroidal transformer
    By Neale in forum General Electronics
    Last Post: 05-01-2016, 11:45 PM
  3. Toroid transformer no ouput
    By eurikain in forum Electronic Project Building
    Last Post: 16-12-2015, 03:54 PM
  4. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  5. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
