    So some 4 core CY 1mm2 cable landed from Farnell on Friday to wire up the spindle - however it's rather on the stiff side, I'm wondering is it worth splashing out on some Lapp Olflex 810 at £4.20/metre, will it be that much better?? or does anyone know of a source of a nice flexible type please?
    Usually CY cable works fine and will soften up in use. Personally, I'd use it and if it causes you a problem then replace at later date, but i'm 99% sure it won't.
    I'm using 4 core 1mm CY. Seems stiff at first, but it will run through a cable chain and move about just fine. At my last job, we used the same stuff in bigger sizes. It will soften up.
    Cheers for the advice guys, I'll give it a go.
    I also made sure that there was an extra loop of cable so that it moved more freely, and clipped the cable near the plug on the spindle to make sure that there was no movement between plug and cable - can lead to internal connections fracturing over time.
  1. Porter + Cable spindle
    By kell in forum Items For Sale
    Last Post: 26-06-2021, 12:10 PM
  2. Which thickness CY cable do I need for 1.5kW spindle?
    By bee in forum Generic Chinese Spindles
    Last Post: 19-03-2017, 08:43 AM
  3. 1.5 kw Chinese spindle cable
    By 142victoria in forum Generic Chinese Spindles
    Last Post: 02-11-2015, 09:53 AM
  4. VFD Cable and 2.2kw spindle wiring
    By Flamered in forum Spindles & Drive Motors
    Last Post: 24-08-2012, 07:29 PM
  5. Stiff 1610 ballscrews, need help.... asap.
    By ccmarco in forum Lead Screws, Nuts & Supports
    Last Post: 05-12-2010, 10:01 AM
