Thread: Newbie from NZ
Doddy
can you please help
ive installed 3 of the uniquegoods 30 amp controllers with npn switches each end
all works 100% BUT i want to get rid of the remotes and use a simple push button hand controller
ive wired this into the manual switch but i can only get it to work by using only 2 of the 4 wires. i think im grounding the circuit so infact closing the switch. trouble as soon as i release the button the motor stops ( with remote it stays ngaged until it hits the npn switch. is there a quick fix to turn this bit into a stay on system so when release the BUTTON it keeps moving until it hits the end then it reverses the direction. As said it works NOW with the remote as one press keeps it moving. Do i need to wire the handpiece differently or use the 2 other wires in the manual bit. ( says that using the manual makes the remote redundant but it doesnt do this . Any help cheers Richard
