05-09-2019 #1
This CNC kit included:
1 x Closed Loop Stepper Driver 0~8.2A 24~80VDC for Nema 34 Stepper Motor
1 x Nema 34 Closed Loop Stepper Motor 4.6Nm/651.54oz.in Encoder 1000CPR
1 x 1.7 m(67") Long Encoder Extension Cable for Closed Loop Stepper Driver
1 x RV-4 AWG18 1.7 m(67") Long Motor Extension Cable with GX16 Aviation Plug for Nema 34 Closed Loop Stepper Motors(Just for aviation-plug model motor)
Motor Specification
Manufacturer Part Number: 34HS31-6004D-E1000
Motor Type: Bipolar Stepper
Step Angle: 1.8 deg
Frame Size: 86 x 86 mm
Holding Torque: 4.6 N.m(651.54 oz.in)
Rated Current/phase: 6 A
Shaft Diameter: Φ14 mm
Shaft Length: 40 mm
Key-Way Length: 25 mm
Phase Resistance: 0.3 ohm
Inductance: 2.3 mH ± 20%(1KHz)
Number of Leads: 4
Lead Length: 300 mm
Driving Voltage : 5V
Output current : 55mA
Resolution : 1000ppr
Output Signal : 2 Channels
Bore Diameter : Φ8mm
Output Frequency : ≤1MHz
Running Speed : ≤5000rpm
IP Protection : IP20
https://www.omc-stepperonline.com/cl...or-driver.html
https://www.omc-stepperonline.com/wa...r-1000cpr.html
Electrical Specification
Number of phase: 2
Step Angle: 1.8 deg
Holding Torque: 1.2 Nm(169.97 oz.in)
Rated Current/phase: 4.0 A
Phase Resistance: 0.45 ohms
Inductance: 1.4 mH ± 20%(1KHz)
Physical Specification
Frame Size: 57 x 57 mm
Body Length: 65 mm
Shaft Diameter: Φ8 mm
Shaft Length: 21 mm
D-Cut Shaft Length: 15 mm
Lead Length: 1000 mm
Weight: 0.8 kg
Encode Control(1000CPR)
Black--GND
Red--+5VCC
Blue/White--EA-
Blue--EA+
Orange/White--EB-
Orange--EB+
https://bit.ly/2md8s3P
Number of phase: 2
Step Angle: 1.8 deg
Holding Torque: 72 Ncm(101.98 oz.in)
Rated Current/phase: 2.0 A
Phase Resistance: 1.75 ohms
Inductance: 4.0 mH ± 20%(1KHz)
Frame Size: 42 x 42 mm
Body Length: 60 mm
Shaft Diameter: Φ5 mm
Shaft Length: 24 mm
Number of Leads: 4
Lead Length: 450 mm
Weight: 0.5 kg
Brake Connections
Red--24V+
Red--24V-
0.5NmLast edited by Lee Roberts; 19-09-2019 at 12:15 PM.
12-09-2019 #2
These commercial adverts should be in the Manufacturer News section, not in Classified Ads.
The Following 2 Users Say Thank You to AndyUK For This Useful Post:
19-09-2019 #3
OMC,
Please note:
We strictly DO NOT accept and/or tolerate any form of spam, our members are very proactive in reporting this kind of behaviour and you WILL be reported !
We have a special sub forum to accommodate you, please post your future offerings there, see below link:
Manufacturer News
This is our commercial forum, submission to any other is strictly prohibited.
All threads have been merged, re titled and moved accordingly.
Andy,
Thanks for spotting this and respondingLast edited by Lee Roberts; 19-09-2019 at 11:41 AM. Reason: grammer
.Me
19-09-2019 #4
Additionally,
I've been able to arrange a 5% discount code for forum members to use!
The code is below, simply add it to your cart when checking out on their website and the discount will be applied.
Code:Coupon Code: MYCNCUK
I've attached some pics of how I received the motors and everything went well:
DataSheet:
http://www.mycncuk.com/attachment.ph...7&d=1568888995
You'll note I said Nema24 not Nema23 ?
As far as I could tell at the time, the 3.1Nm motors we usually suggest from CNC4YOU: Stepper Motor Kit 3.1Nm x 3 Axis + 3 Mounts Nema23, are pretty much the same, the only difference I could see was the Rear Shaft and Wire length.
DataSheet:
http://www.mycncuk.com/attachment.ph...6&d=1568888945
They have UK stock for allot of items and multiple EU warehouse locations they can ship from, I actually had to wait for their UK stock to be replenished and as i wasn't in a rush that's what I did, of course they always have stock in their China location if you don't mind waiting longer and would be happy to pay any import costs.
I ordered on Saturday and the motors turned up at 11:00 Wednesday morning, top marks for the packaging:
Dual Shaft Nema 24 CNC Stepper 3.1Nm (439 oz.in) 60x60x80mm 8 Wires
- Ship from: United Kingdom
Sub-Total: £79.48
Coupon (MYCNCUK): £-3.97
Royal Mail Tracked 48: £2.83
Total: £78.33.Me
The Following User Says Thank You to Lee Roberts For This Useful Post:
19-09-2019 #5
Well done Lee!
I've bought motors and drivers from Stepperonline (usually the Australian warehouse) for several projects and always been happy with the service, prices and products.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
19-09-2019 #6
20-09-2019 #7
It's my understanding that the NEMA size is the width of the frame in tenths of an inch.
20-09-2019 #8
No because I new that already...or did you want me to so as to confirm?
That's what caught my eye, I think the units from 4U are actually Nema24 because the tech doc for their motors says a 60 frame...
They do have other nema 23 stepper motor listings, the x3 offer is here: https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23, that shows a slightly different model number of 60BYGH301B vs the doc for all of the motors reading 60BYG301B...
Those listings do show a different looking unit...they all show as out of stock at the mo...maybe there phasing out the ones below or something:
I don't suppose any of this matters really just my observations, all I really wanted to do is share that OMC are cheaper and seem to have a pretty ridiculously good like for like motor...
If the CNC4YOU listings and documents are correct of course...
Thanks Kit,
Yea its 2.3" and 2.4", I've always just called them 57mm or 60mm....Me
09-10-2019 #9
Hi Lee, thanks for your support! We are offering big discounts on some hot sale products, up to 43% off! Have a look if you are interested. https://www.omc-stepperonline.com/sale.html/
21-03-2022 #10
I also bought motors from Stepperonline,
Metal Supply - 1stChoiceMetals.co.uk - 10% Discount Offer.
By 1st Choice Metals in forum Manufacturer NewsReplies: 0Last Post: 21-11-2016, 12:59 PM -
10% Discount weekend At Zapp Automation
By Gary in forum Marketplace DiscussionReplies: 10Last Post: 19-02-2012, 12:42 PM -
Zapp Automation Discount Weekend !
By Gary in forum Manufacturer NewsReplies: 6Last Post: 21-08-2011, 11:29 PM -
NEW MEMBER: Hello to all members
By HUKBMBEAR in forum New Member IntroductionsReplies: 2Last Post: 24-08-2010, 05:00 PM -
NEW MEMBER: New Members
By airwolf in forum New Member IntroductionsReplies: 2Last Post: 02-11-2009, 06:31 PM
