15-09-2019 #21
The VFD itself doesn't cause interference until the spindle is running so would it need a ferrite on the spindle CY cable? Also I have already got all shielding running to a central bank of earth terminals on the sun rail but I thought we were only supposed to connect one end...are we meant to earth both ends?
Sent from my SM-G920F using Tapatalk
15-09-2019 #22
https://www.emcstandards.co.uk/cable...t-one-end-only is an interesting read.
Ask 10 people and you'll get 12 different replies.
I work in an industry where EM emissions and susceptibility are treated very seriously, and at relatively high power levels. Power systems (emissives) are typically, within these systems, shielded both ends.
You'll find that as the VFD is placed under load it will present some of the heavier switching currents onto it's supply lines. Hence the ferrites. But, horses for courses.Last edited by Doddy; 15-09-2019 at 02:52 PM.
15-09-2019 #23
...but there's not enough popcorn in the world to cater for the ensuring arguments.
21-09-2020 #24
i have the same setup anychance you have pictures of the actual connections
on the vfd and the axbb-e because it is driving me nuts
cheers
23-09-2020 #25
finally got it going no relay needed
removed jumper then
A01 = VI
ACM = 5V0
DCM = 24V0
FOR = pin 7 port 1
REV = pin 8 port 1
pid001 on vfd = 1
pid002 on vfd = 1
AXBB charge pump fault
By CharlieRam in forum CNCdrive (UC100, UC300ETH)Replies: 78Last Post: 18-07-2021, 08:31 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
got 2 outputs from controller, need to connect 3 leds to them, any solution?
By Noplace in forum CS-Lab (CSMIO)Replies: 5Last Post: 04-02-2016, 08:51 PM -
Advice needed for controller box layout
By Bustercnc in forum General ElectronicsReplies: 23Last Post: 18-01-2016, 01:16 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM
