Connect the VFD ACM (analogue ground) to your 0V/GND level, and the AXBB analogue AO1 output to VI input to the VFD. That gives you your 0-10V control.
Now, I expect O2 and O3 outputs are designated forward/reverse, so connect these to the FOR and REV inputs to the VFD. As these are digital inputs to the VFD you'd best connect the DCM (digital ground) to your 0V/GND as well.
You say you've set PD00... : so I guess you've unlocked PD000, PD001 = run control = external = 1?, PD002 = operating freq = external = 1, PD044 = FOR = 2, PD045 = REV = 3, PD070 = 0-10V = 0 etc?Last edited by Doddy; 14-09-2019 at 10:39 AM.
AXBB charge pump fault
By CharlieRam in forum CNCdrive (UC100, UC300ETH)Replies: 78Last Post: 18-07-2021, 08:31 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
got 2 outputs from controller, need to connect 3 leds to them, any solution?
By Noplace in forum CS-Lab (CSMIO)Replies: 5Last Post: 04-02-2016, 08:51 PM -
Advice needed for controller box layout
By Bustercnc in forum General ElectronicsReplies: 23Last Post: 18-01-2016, 01:16 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM
