With VI connected to 5V+ ?, I'm assuming that's what you're talking about and the rest of this only makes sense if this is what you mean.
So, connecting 5V into a 0-10V input you would expect 1/2 max speed (I assume 12000 RPM).
You now still need to understand how to get 0-10V from the PWM output from the AXBB. I'm AFK for a short while (wife stops play) then I'll google the AXBB manual a bit more. If you can recover the wiring to have the AO1 connected to the VI on the VFD and any further intelligence from your side?
AXBB charge pump fault
By CharlieRam in forum CNCdrive (UC100, UC300ETH)Replies: 78Last Post: 18-07-2021, 08:31 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
got 2 outputs from controller, need to connect 3 leds to them, any solution?
By Noplace in forum CS-Lab (CSMIO)Replies: 5Last Post: 04-02-2016, 08:51 PM -
Advice needed for controller box layout
By Bustercnc in forum General ElectronicsReplies: 23Last Post: 18-01-2016, 01:16 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM
