Thread: switches settings in mach3
Hi all,
I installed switches to my 6040 today (parallel running 2xX 2xY 2xZ) and cannot get mach3 to register them.
I am using a UC400eth controller so no printer cable connection used and i have tested the physical side which all checks out correctly done. i set them as pin 11,12 and 13 for xyz home. any suggestions on what I'm missing?
Almost forgot i set them up as open circuit.
Kind RegardsLast edited by Palletlad; 14-09-2019 at 10:47 PM.
15-09-2019 #2
What type of switch.? There are many types with some differences in how they connect.
If proximity Switches then are they NPN or PNP.? How did you wire them, which colours where.?
We need more details than just pin numbers
17-09-2019 #3
1st. I thought you normally wire the 2 limit switches in series per axis?
2nd. NC or NO difference is represented by either Active low or Active high.
For 2 wire units I'd wire it as + power from the supply and negative to the pin.
Clueless about 3 wire.
Work out which type of switch you have, google search diagrams in images, the information is easily found, research.
That's about as far as my knowledge goes.Last edited by dazp1976; 17-09-2019 at 05:47 PM.
Help please. Dip switches and mach 3 settings
By Radu_Andrei in forum Motor Drivers & ControllersReplies: 261Last Post: 16-11-2019, 02:48 PM -
G540, homing switches and mach3
By marbles in forum Artsoft Mach (3 & 4)Replies: 11Last Post: 02-06-2018, 02:55 PM -
Mach3 Setting up home and limit switches
By CrazeUK in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 03-02-2017, 01:18 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM -
Limit switches and Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 06-03-2013, 10:51 AM
