Now then, the motors that move the torch will likely be working off STEP (how many increments) and DIRECTION (L or R) signals, it looks like the latter isn't working - could be as simple as a bad connection, shouldn't be too difficult to diagnose. Have you done some Googling? a quick search pulled up this page:
https://www.candcnc.net/
which seems to be something to do wit Blade Runner machines, there's something about support and a user forum by the looks.
17-09-2019 #2
Thanks for the reply, it is much appreciated.
The Cancnc forum was helpful, and it got me through initial set up issues, however, the latest problems don’t seem like easy fixes.
I tried all sorts of configurations on the motors (pins and outputs) but nothing seems to change the problem.
The strange thing is that each time I start up, the problem seems slightly different. On one start up everything worked fine, but without changing anything, the very next start up, had the gantry making a graunching sound, and randomly jiggling around.
I am going to try disconnecting all the interface cables and check for pin problems etc. The MP3000e box looks pretty battered about.
Thanks again.
18-09-2019 #3
Without knowing what you have - if it's at all possible to swap the X and Y axis cables to the motors at the control box - try that and see if the problem remains on the X-axis. If it does, then it's the wiring or the motor, if the problem swaps to the Y-axis then it's the control box.
18-09-2019 #4
19-09-2019 #5
If it's only going in one direction with either keypress on just one axis then it's usually 99% of the time a Bad Connection on the Direction Pin. It's certainly the first place to look.
If it's doing this on more than one axis then I'd look at the Keyboard first and just replace it.
After this, it starts getting a bit more into the unknown and could be anything from bad connection/broken wire to controller or drive on it's way out.?? . . . . More info would be needed to advise properly.Last edited by JAZZCNC; 19-09-2019 at 06:36 PM.
19-09-2019 #6
On my 3dD printer, there is one cable that connects a stepper that moves a lot, I have changed it twice in the lifetime of the printer as a cable intermittent break causes it to be biased in one direction. The same has happened on the Z axis of my CNC router and that was also a break in one conductor of the stepper cable.
Sheet support for a plasma machine?
By Davek0974 in forum Plasma Table MachinesReplies: 11Last Post: 10-02-2014, 08:44 PM -
App calculator feed and speed windows phone
By hoezap in forum Computer SoftwareReplies: 2Last Post: 14-02-2013, 11:44 PM -
OneCNC - The Mobile Phone
By Gilly in forum OneCNCReplies: 9Last Post: 18-05-2009, 07:56 PM -
plasma build log - sort of
By mike techserv in forum DIY Plasma Build LogsReplies: 0Last Post: 23-04-2009, 10:15 AM
