	19-09-2019 #1I've used and killed these drives.! . . They don't tolerate any overvoltage. 51V will 100% Kill them and with Back EMf and/or Mains fluctuations you will hit 51V with 36V primary. I Wouldn't go much above 30Vdc with Prime and to be honest you won't notice any difference the few volts gives you.
	19-09-2019 #2Hi Jazz
 I'm always glad to hear of someones own experience of an electronic piece of equipment. My cnc machine is going to be mainly used for carving wood, guitar making etc. Is the improvement in a closed loop system worth the upgrade? I've got the parts Leadshine MX3660 , steppers are https://www.upload.sorotec.de/doku/m...T6018L3008.pdf and an AXBB-e controller. If it's worth it in performance I would upgrade as I haven't put the machine together yet and the time saved as opposed to removing the motors and upgrading later would be worth doing it now rather than later.
 Andrew
	19-09-2019 #3Hi Jazz
 No need to reply on this. I've just checked out some of your previous posts, which lets me think that staying with what I have will be good enough for what I need.
 Andrew
	19-09-2019 #4
	19-09-2019 #5Well youv'e got me thinking after your last reply. I can you the bits I have to upgrade an older machine and don't mind spending a few bob on something that runs better and I will be doing a fair amount of 2.5/3d cutting, and i'm getting old so anything that runs a bit better (quicker smoother ) i'm happy to invest in. Now the killer question is are the stepperonline kits ok (they seem to have great prices and there seems to be a 5% discount for us members) or should I look around a bit.
 Andrew
	19-09-2019 #6
	19-09-2019 #7Thanks good to know.
 Andrew
	19-09-2019 #8Yes, there is a difference compared to a standard stepper, esp when doing 3D type work with lots of fast small movements as the closed-loop system ensures position with fast direction changes.
 I've used about 12 sets now of closed-loop systems from different manufacturers and varying sizes from 2Nm nema23 to 12Nm nema 34 and all of them perform better than standard stepper system. Basicly just a little bit stronger, little smoother and in general feel more reliable.
 However,Like wise I've built Dozens of machines using standard stepper systems without any problems. So if you have sized the motors/drives/voltage correctly for the size of your machine and left enough power for when running at higher feeds then you won't have issues.
 Personaly because you already have the parts, provided they are sized correctly then I wouldn't have any qualms using them at all.
 If you were buying from scratch then I'd Say get Closed-loop everytime because the difference is price isn't so great now and the extra cost is worth it.
  FOR SALE: Stepper Motor Power Supply From Zapp AutomationBy MrBurns in forum Items For SaleReplies: 1Last Post: 02-10-2017, 04:54 PM
  Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + EncoderBy george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM
  Testing Leadshine closed loop stepper system.By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM
  Closed Loop Stepper Compared with Open Loop StepperBy Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
  Closed Loop steppersBy funkmonkey in forum Stepper & Servo MotorsReplies: 24Last Post: 18-07-2009, 09:56 PM
