    What's the primary coil rating of the toroidal? If 220V then you might be well over the design limit of 48V with a 240V supply.
    Personally, if the rectified voltage was 49-50V I probably wouldn't lose sleep over using them myself, but would never design around this for a third party.
    Hi Doddy
    We have 220 volts here in Austria,
    cheers
    Andrew
    Doddy's Avatar
    ** Ignore, I'm getting Austria and Australia confused **
    (Looks at watch: I'm going back to bed...)
    Well it looks like i'm veering towards the following configuration.
    https://www.omc-stepperonline.com/1-...or-driver.html
    I'm not sure which one of these to choose as the price is only a few euros more in the stronger motor.
    https://www.omc-stepperonline.com/po...-s-500-36.html
    I could by a new transformer to go with parts I have from my previous unregulated supply but would probably cost as much or more as the switching supply above.
    The machine this lot would go on is the following which I already have.
    https://www.sorotec.de/shop/Portal-m...-DIY-4862.html
    Its main use would be for wood carving (guitar making ) and some light metal/plastic milling. Any opinions would be gratefully accepted. Looking at the steppersonline site I like the idea from buying from one scource. They seem to have all the extra cable extensions etc. at a reasonable price and ship from Europe which saves a lot in Duty and taxes.
    Andrew
  1. FOR SALE: Stepper Motor Power Supply From Zapp Automation
    By MrBurns in forum Items For Sale
    Last Post: 02-10-2017, 04:54 PM
  2. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  3. Testing Leadshine closed loop stepper system.
    By JAZZCNC in forum Stepper & Servo Motors
    Last Post: 13-10-2012, 05:39 PM
  4. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
  5. Closed Loop steppers
    By funkmonkey in forum Stepper & Servo Motors
    Last Post: 18-07-2009, 09:56 PM
