    Quote Originally Posted by Richardtweed View Post
    Thanks for replying mate, I tried all that before I posted lol, I'm assuming it's a 360 issue but I have been trying for a few days now with no look, stressful is not the word ��
    Then it's not Mach3 which answers half your question.! . . . There is one other possibility.? Check you don't have a tool height offset set in tool table.
    can you make a simple program such as a 50mm square part, face it off and post the code so we can see what fusion is producing
    I will do that now as I'm still trying to fix it, its driving me crazy. I have played about with the hights in fusion 360 with no look. Mach 3 is showing it to be 2mm above the zero so it knows where the end mill is at least.
    I ran a test piece and it cut everything fine so a copied the hights I used in 360 that were pre-set and used them on the work I am having issues with and it still started cutting 2mm above the z axis zero height which has frustrated me even further, the readout on mach3 knows it is cutting +2mm
  5. #15
    Explain what you mean by copied the heights.! . . Copied them to where.?
    post the code your having trouble with so can check it out.
  6. #16
    I mean the retract height, stock height ect. The heights tab in fusion 360.
    I will post the codes first thing in the morning
  7. #17
    I think I know what is happening. You have your top height as stock top rather than model top. If there is stock left on in your setup then it will try to machine that away first by starting in free air above your zero. When you post your code tomorrow send a picture of the stock tab in the setup so we can check that out too
  8. #18
    (1001)
    (t1 d=2.97 cr=0. - zmin=-3. - flat end mill)
    g90 g94 g91.1 g40 g49 g17
    g21
    g28 g91 z0.
    G90
    (bore1)
    m5
    m9
    t1 m6
    s8000 m3
    g54
    g0 x-34.088 y0.711
    g43 z5. H1
    g1 z3.297 f1000.
    G18 g3 x-34.385 z3. I-0.297 k0.
    G1 x-34.534
    g17 g2 x-34.831 y1.008 i0. J0.297
    x-18.801 z2.9 i8.015 j0.
    X-34.831 z2.8 i-8.015 j0.
    X-18.801 z2.7 i8.015 j0.
    X-34.831 z2.6 i-8.015 j0.
    X-18.801 z2.5 i8.015 j0.
    X-34.831 z2.4 i-8.015 j0.
    X-18.801 z2.3 i8.015 j0.
    X-34.831 z2.2 i-8.015 j0.
    X-18.801 z2.1 i8.015 j0.
    X-34.831 z2. I-8.015 j0.
    X-18.801 z1.9 i8.015 j0.
    X-34.831 z1.8 i-8.015 j0.
    X-18.801 z1.7 i8.015 j0.
    X-34.831 z1.6 i-8.015 j0.
    X-18.801 z1.5 i8.015 j0.
    X-34.831 z1.4 i-8.015 j0.
    X-18.801 z1.3 i8.015 j0.
    X-34.831 z1.2 i-8.015 j0.
    X-18.801 z1.1 i8.015 j0.
    X-34.831 z1. I-8.015 j0.
    X-18.801 z0.9 i8.015 j0.
    X-34.831 z0.8 i-8.015 j0.
    X-18.801 z0.7 i8.015 j0.
    X-34.831 z0.6 i-8.015 j0.
    X-18.801 z0.5 i8.015 j0.
    X-34.831 z0.4 i-8.015 j0.
    X-18.801 z0.3 i8.015 j0.
    X-34.831 z0.2 i-8.015 j0.
    X-18.801 z0.1 i8.015 j0.
    X-34.831 z0. I-8.015 j0.
    X-18.801 z-0.1 i8.015 j0.
    X-34.831 z-0.2 i-8.015 j0.
    X-18.801 z-0.3 i8.015 j0.
    X-34.831 z-0.4 i-8.015 j0.
    X-18.801 z-0.5 i8.015 j0.
    X-34.831 z-0.6 i-8.015 j0.
    X-18.801 z-0.7 i8.015 j0.
    X-34.831 z-0.8 i-8.015 j0.
    X-18.801 z-0.9 i8.015 j0.
    X-34.831 z-1. I-8.015 j0.
    X-18.801 z-1.1 i8.015 j0.
    X-34.831 z-1.2 i-8.015 j0.
    X-18.801 z-1.3 i8.015 j0.
    X-34.831 z-1.4 i-8.015 j0.
    X-18.801 z-1.5 i8.015 j0.
    X-34.831 z-1.6 i-8.015 j0.
    X-18.801 z-1.7 i8.015 j0.
    X-34.831 z-1.8 i-8.015 j0.
    X-18.801 z-1.9 i8.015 j0.
    X-34.831 z-2. I-8.015 j0.
    X-18.801 z-2.1 i8.015 j0.
    X-34.831 z-2.2 i-8.015 j0.
    X-18.801 z-2.3 i8.015 j0.
    X-34.831 z-2.4 i-8.015 j0.
    X-18.801 z-2.5 i8.015 j0.
    X-34.831 z-2.6 i-8.015 j0.
    X-18.801 z-2.7 i8.015 j0.
    X-34.831 z-2.8 i-8.015 j0.
    X-18.801 z-2.9 i8.015 j0.
    X-34.831 z-3. I-8.015 j0.
    X-18.801 i8.015 j0.
    X-34.831 i-8.015 j0.
    X-34.534 y1.305 i0.297 j0.
    G1 x-34.385
    g18 g2 x-34.088 z-2.703 i0. K0.297
    g0 z5.
    G17
    (2d pocket1)
    g0 z11.
    X-12.508 y-0.109
    z5.797
    g1 z2.997 f1000.
    X-12.512 z2.951
    x-12.523 z2.905
    x-12.541 z2.862
    x-12.565 z2.822
    x-12.595 z2.787
    x-12.631 z2.757
    x-12.67 z2.732
    x-12.713 z2.715
    x-12.759 z2.704
    x-12.805 z2.7
    x-13.81 y-0.111
    x-18.815 y-0.12
    x-18.816
    g2 x-19.016 y0.079 i0. J0.2
    g1 x-19.029 y2.192
    g2 x-18.829 y2.393 i0.2 j0.001
    g1 x-13.807
    g2 x-13.61 y2.227 i0. J-0.2
    g1 x-12.843 y-2.246
    g2 x-13.04 y-2.48 i-0.197 j-0.034
    g1 x-19.535 y-2.491
    x-19.536
    g2 x-19.736 y-2.295 i0. J0.2
    g1 x-19.861 y4.561
    g2 x-19.661 y4.765 i0.2 j0.004
    g1 x-13.031
    g2 x-13.03 y3.579 i0. J-0.593
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g2 x-19.951 y4.313 i0.104 j0.584
    g1 x-21.958 y6.101
    g2 x-21.564 y7.136 i0.394 j0.443
    g1 x-11.218
    g2 x-11.018 y6.935 i0. J-0.2
    g1 x-11.065 y-4.649
    g2 x-11.265 y-4.848 i-0.2 j0.001
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g2 x-34.579 y-2.196 i0. J0.319
    g1 y-1.208
    y3.229
    y4.445
    g2 x-34.259 y4.765 i0.319 j0.
    G1 x-33.958
    g2 x-33.761 y4.598 i0. J-0.2
    g1 x-32.179 y-4.647
    g2 x-32.376 y-4.88 i-0.197 j-0.034
    g1 x-36.631 y-4.887
    g2 x-36.95 y-4.567 i0. J0.319
    g1 y6.817
    g2 x-36.631 y7.136 i0.319 j0.
    G1 x-32.077
    g2 x-31.653 y6.129 i0. J-0.593
    g1 x-35.683 y1.997
    g3 x-35.764 y1.274 i0.425 j-0.414
    g1 x-32.377 y-4.287
    g3 x-31.908 y-4.571 i0.506 j0.308
    g1 x-7.98 y-6.079
    g2 x-8.017 y-7.263 i-0.037 j-0.592
    g1 x-37.812
    g2 x-39.327 y-5.748 i0. J1.515
    g1 y7.998
    g2 x-37.812 y9.513 i1.515 j0.
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z2.628 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z2.427
    g2 x-13.81 y-0.111 z2.4 i-1.075 j0.913
    g1 x-18.815 y-0.12 f1000.
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z2.328 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z2.127
    g2 x-13.81 y-0.111 z2.1 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z2.028 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z1.827
    g2 x-13.81 y-0.111 z1.8 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z1.728 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z1.527
    g2 x-13.81 y-0.111 z1.5 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z1.428 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z1.227
    g2 x-13.81 y-0.111 z1.2 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z1.128 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z0.927
    g2 x-13.81 y-0.111 z0.9 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z0.828 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z0.627
    g2 x-13.81 y-0.111 z0.6 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z0.528 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z0.327
    g2 x-13.81 y-0.111 z0.3 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z0.228 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z0.027
    g2 x-13.81 y-0.111 z0. I-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-0.072 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-0.273
    g2 x-13.81 y-0.111 z-0.3 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-0.372 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-0.573
    g2 x-13.81 y-0.111 z-0.6 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-0.672 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-0.873
    g2 x-13.81 y-0.111 z-0.9 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-0.972 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-1.173
    g2 x-13.81 y-0.111 z-1.2 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-1.272 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-1.473
    g2 x-13.81 y-0.111 z-1.5 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-1.572 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-1.773
    g2 x-13.81 y-0.111 z-1.8 i-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    g2 x-6.96 y7.189 z-1.848 i0. J-1.411 f333.
    G1 x-12.737 y0.387 z-1.982
    g2 x-13.81 y-0.111 z-2. I-1.075 j0.913
    X-18.816
    g1 x-19.029 y2.192
    g1 x-13.807
    g1 x-12.843 y-2.246
    g1 x-19.535 y-2.491
    x-19.536
    g1 x-19.861 y4.561
    g1 x-13.031
    g1 x-16.24 y3.57
    x-16.293 y3.572
    x-16.346 y3.579
    x-19.661 y4.172
    g1 x-21.958 y6.101
    g1 x-11.218
    g1 x-11.065 y-4.649
    g1 x-21.243 y-4.864
    x-34.084 y-2.515
    x-34.259
    g1 y-1.208
    y3.229
    y4.445
    G1 x-33.958
    g1 x-32.179 y-4.647
    g1 x-36.631 y-4.887
    g1 y6.817
    G1 x-32.077
    g1 x-35.683 y1.997
    g1 x-32.377 y-4.287
    g1 x-7.98 y-6.079
    g1 x-37.812
    g1 y7.998
    G1 x-9.291
    x-8.035
    x-7.989 y9.509
    x-7.038 y9.359
    x-6.992 y9.351 z-1.996
    x-6.947 y9.344 z-1.985
    x-6.905 y9.338 z-1.968
    x-6.865 y9.331 z-1.943
    x-6.83 y9.326 z-1.913
    x-6.801 y9.321 z-1.878
    x-6.777 y9.317 z-1.838
    x-6.759 y9.315 z-1.795
    x-6.748 y9.313 z-1.749
    x-6.745 y9.312 z-1.703
    g0 z11.
    X-4.714 y-3.992
    z5.797
    g1 z2.7 f1000.
    G2 x-5.9 y-3.994 i-0.593 j0.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g2 x-5.094 y2.622 i0.583 j-0.11
    g1 x-3.3 y4.056
    g2 x-2.337 y3.592 i0.37 j-0.463
    g1 y-5.325
    g2 x-5.094 y-5.746 z2.629 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z2.487
    g2 x-6.338 y3.664 z2.443 i1.346 j0.421
    x-4.714 y2.269 z2.4 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z2.329 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z2.187
    g2 x-6.338 y3.664 z2.143 i1.346 j0.421
    x-4.714 y2.269 z2.1 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z2.029 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z1.887
    g2 x-6.338 y3.664 z1.843 i1.346 j0.421
    x-4.714 y2.269 z1.8 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z1.729 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z1.587
    g2 x-6.338 y3.664 z1.543 i1.346 j0.421
    x-4.714 y2.269 z1.5 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z1.429 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z1.287
    g2 x-6.338 y3.664 z1.243 i1.346 j0.421
    x-4.714 y2.269 z1.2 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z1.129 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z0.987
    g2 x-6.338 y3.664 z0.943 i1.346 j0.421
    x-4.714 y2.269 z0.9 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z0.829 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z0.687
    g2 x-6.338 y3.664 z0.643 i1.346 j0.421
    x-4.714 y2.269 z0.6 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z0.529 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z0.387
    g2 x-6.338 y3.664 z0.343 i1.346 j0.421
    x-4.714 y2.269 z0.3 i0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    g2 x-5.094 y-5.746 z0.229 i-1.411 j0. F333.
    G1 x-7.471 y1.848 z0.087
    g2 x-6.338 y3.664 z0.043 i1.346 j0.421
    x-4.714 y2.269 z0. I0.213 j-1.395
    g1 y-3.992 f1000.
    G1 x-5.91 y-0.974
    x-5.908 y-0.917
    x-5.9 y-0.862
    x-5.307 y2.269
    g1 x-3.3 y4.056
    g1 y-5.325
    x-2.341 y-5.371
    x-2.491 y-6.323
    x-2.499 y-6.368 z0.004
    x-2.506 y-6.413 z0.015
    x-2.513 y-6.456 z0.032
    x-2.519 y-6.495 z0.057
    x-2.524 y-6.53 z0.087
    x-2.529 y-6.56 z0.122
    x-2.533 y-6.584 z0.162
    x-2.536 y-6.601 z0.205
    x-2.537 y-6.612 z0.251
    x-2.538 y-6.616 z0.297
    g0 z11.
    X26.158 y-12.375
    z5.797
    g1 z2.967 f1000.
    X26.161 z2.925
    x26.17 y-12.373 z2.885
    x26.186 y-12.371 z2.846
    x26.208 y-12.367 z2.81
    x26.235 y-12.363 z2.778
    x26.266 y-12.358 z2.751
    x26.302 y-12.353 z2.729
    x26.34 y-12.347 z2.713
    x26.38 y-12.34 z2.703
    x26.422 y-12.334 z2.7
    x27.415 y-12.176
    x27.461 y-12.173
    x32.834
    y-14.29
    y-12.173 z2.672 f333.
    X27.461 z2.6
    x32.834 z2.528
    y-14.29 z2.5
    y-12.173 z2.472
    x27.461 z2.4
    x32.834 f1000.
    Y-14.29
    y-12.173 z2.372 f333.
    X27.461 z2.3
    x32.834 z2.228
    y-14.29 z2.2
    y-12.173 z2.172
    x27.461 z2.1
    x32.834 f1000.
    Y-14.29
    y-12.173 z2.072 f333.
    X27.461 z2.
    X32.834 z1.928
    y-14.29 z1.9
    y-12.173 z1.872
    x27.461 z1.8
    x32.834 f1000.
    Y-14.29
    y-12.173 z1.772 f333.
    X27.461 z1.7
    x32.834 z1.628
    y-14.29 z1.6
    y-12.173 z1.572
    x27.461 z1.5
    x32.834 f1000.
    Y-14.29
    y-12.173 z1.472 f333.
    X27.461 z1.4
    x32.834 z1.328
    y-14.29 z1.3
    y-12.173 z1.272
    x27.461 z1.2
    x32.834 f1000.
    Y-14.29
    y-12.173 z1.172 f333.
    X27.461 z1.1
    x32.834 z1.028
    y-14.29 z1.
    Y-12.173 z0.972
    x27.461 z0.9
    x32.834 f1000.
    Y-14.29
    y-12.173 z0.872 f333.
    X27.461 z0.8
    x32.834 z0.728
    y-14.29 z0.7
    y-12.173 z0.672
    x27.461 z0.6
    x32.834 f1000.
    Y-14.29
    y-12.173 z0.572 f333.
    X27.461 z0.5
    x32.834 z0.428
    y-14.29 z0.4
    y-12.173 z0.372
    x27.461 z0.3
    x32.834 f1000.
    Y-14.29
    y-12.173 z0.272 f333.
    X27.461 z0.2
    x32.834 z0.128
    y-14.29 z0.1
    y-12.173 z0.072
    x27.461 z0.
    X32.834 f1000.
    Y-14.29
    x32.831 y-14.337
    x32.68 y-15.288
    x32.673 y-15.334 z0.004
    x32.666 y-15.379 z0.015
    x32.659 y-15.421 z0.032
    x32.653 y-15.46 z0.057
    x32.647 y-15.495 z0.087
    x32.642 y-15.525 z0.122
    x32.639 y-15.549 z0.162
    x32.636 y-15.567 z0.205
    x32.634 y-15.578 z0.251
    y-15.581 z0.297
    g0 z11.
    X32.635 y14.085
    z5.797
    g1 z2.997 f1000.
    X32.632 y14.083 z2.951
    x32.623 y14.078 z2.905
    x32.607 y14.069 z2.862
    x32.586 y14.058 z2.822
    x32.559 y14.043 z2.787
    x32.528 y14.026 z2.757
    x32.493 y14.007 z2.732
    x32.455 y13.987 z2.715
    x32.415 y13.965 z2.704
    x32.374 y13.943 z2.7
    x30.291 y12.813
    x30.255 y12.796
    x30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    G2 x28.8 y12.978 i0. J0.2
    x29.009 y13.174 i0.2 j-0.004
    g1 x32.643 y13.016
    g2 x32.834 y12.817 i-0.009 j-0.2
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z2.612 i0. J1.411 f333.
    G1 x28.604 y15.034 z2.529
    g2 x30.741 y14.906 z2.465 i1.014 j-0.981
    x30.291 y12.813 z2.4 i-1.124 j-0.853
    g1 x30.255 y12.796 f1000.
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z2.312 i0. J1.411 f333.
    G1 x28.604 y15.034 z2.229
    g2 x30.741 y14.906 z2.165 i1.014 j-0.981
    x30.291 y12.813 z2.1 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z2.012 i0. J1.411 f333.
    G1 x28.604 y15.034 z1.929
    g2 x30.741 y14.906 z1.865 i1.014 j-0.981
    x30.291 y12.813 z1.8 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z1.712 i0. J1.411 f333.
    G1 x28.604 y15.034 z1.629
    g2 x30.741 y14.906 z1.565 i1.014 j-0.981
    x30.291 y12.813 z1.5 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z1.412 i0. J1.411 f333.
    G1 x28.604 y15.034 z1.329
    g2 x30.741 y14.906 z1.265 i1.014 j-0.981
    x30.291 y12.813 z1.2 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z1.112 i0. J1.411 f333.
    G1 x28.604 y15.034 z1.029
    g2 x30.741 y14.906 z0.965 i1.014 j-0.981
    x30.291 y12.813 z0.9 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z0.812 i0. J1.411 f333.
    G1 x28.604 y15.034 z0.729
    g2 x30.741 y14.906 z0.665 i1.014 j-0.981
    x30.291 y12.813 z0.6 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z0.512 i0. J1.411 f333.
    G1 x28.604 y15.034 z0.429
    g2 x30.741 y14.906 z0.365 i1.014 j-0.981
    x30.291 y12.813 z0.3 i-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    g2 x26.433 y12.789 z0.212 i0. J1.411 f333.
    G1 x28.604 y15.034 z0.129
    g2 x30.741 y14.906 z0.065 i1.014 j-0.981
    x30.291 y12.813 z0. I-1.124 j-0.853
    X30.217 y12.784
    x30.178 y12.776
    x30.138 y12.774
    x29.
    g1 x32.643 y13.016
    g1 y11.434
    y10.397
    x28.819
    x27.447
    x27.4 y10.401
    x26.449 y10.552
    x26.403 y10.559 z0.004
    x26.358 y10.566 z0.015
    x26.316 y10.573 z0.032
    x26.277 y10.579 z0.057
    x26.242 y10.584 z0.087
    x26.212 y10.589 z0.122
    x26.188 y10.593 z0.162
    x26.17 y10.596 z0.205
    x26.159 y10.597 z0.251
    x26.156 y10.598 z0.297
    g0 z11.
    (2d contour1)
    g0 z19.
    X-3.423 y-9.756
    z8.
    G1 z4.3 f333.
    Z2.997
    x-3.427 y-9.757 z2.951
    x-3.437 y-9.758 z2.905
    x-3.455 y-9.759 z2.862
    x-3.479 y-9.761 z2.822
    x-3.51 y-9.764 z2.787
    x-3.545 y-9.767 z2.757
    x-3.585 y-9.77 z2.732
    x-3.627 y-9.774 z2.715
    x-3.673 y-9.778 z2.704
    x-3.719 y-9.782 z2.7
    x-4.015 y-9.807 f1000.
    G2 x-4.336 y-9.536 i-0.025 j0.296
    g3 x-6.812 y-7.263 i-2.476 j-0.212
    g1 x-7.877
    g3 x-8.748 y-6.335 i-1.414 j-0.453
    g1 x-8.775 y-6.324
    x-8.83 y-6.302
    x-8.884 y-6.28
    x-8.938 y-6.257
    x-8.992 y-6.234
    x-9.046 y-6.21
    x-9.1 y-6.186
    x-9.154 y-6.162
    x-9.207 y-6.137
    x-9.26 y-6.112
    x-9.313 y-6.087
    x-9.366 y-6.061
    x-9.419 y-6.035
    x-9.471 y-6.008
    x-9.524 y-5.981
    x-9.576 y-5.954
    x-9.627 y-5.926
    x-9.679 y-5.898
    x-9.73 y-5.869
    x-9.782 y-5.84
    x-9.833 y-5.811
    x-9.884 y-5.781
    x-9.934 y-5.751
    x-9.984 y-5.721
    x-10.035 y-5.69
    x-10.084 y-5.659
    x-10.134 y-5.627
    x-10.184 y-5.596
    x-10.233 y-5.563
    x-10.282 y-5.531
    x-10.33 y-5.498
    x-10.379 y-5.464
    x-10.427 y-5.431
    x-10.475 y-5.397
    x-10.523 y-5.362
    x-10.57 y-5.328
    x-10.618 y-5.293
    x-10.665 y-5.257
    x-10.711 y-5.221
    x-10.758 y-5.185
    x-10.804 y-5.149
    x-10.85 y-5.112
    x-10.895 y-5.075
    x-10.941 y-5.037
    x-10.986 y-5.
    X-11.031 y-4.962
    x-11.075 y-4.923
    x-11.119 y-4.884
    x-11.163 y-4.845
    x-11.207 y-4.806
    x-11.25 y-4.766
    x-11.294 y-4.726
    x-11.336 y-4.686
    x-11.379 y-4.645
    x-11.421 y-4.604
    x-11.463 y-4.563
    x-11.505 y-4.521
    x-11.546 y-4.479
    x-11.587 y-4.437
    x-11.627 y-4.395
    x-11.668 y-4.352
    x-11.708 y-4.309
    x-11.748 y-4.265
    x-11.787 y-4.222
    x-11.826 y-4.178
    x-11.865 y-4.133
    x-11.903 y-4.089
    x-11.941 y-4.044
    x-11.979 y-3.999
    x-12.017 y-3.954
    x-12.054 y-3.908
    x-12.09 y-3.862
    x-12.127 y-3.816
    x-12.163 y-3.769
    x-12.199 y-3.723
    x-12.234 y-3.676
    x-12.269 y-3.628
    x-12.304 y-3.581
    x-12.338 y-3.533
    x-12.372 y-3.485
    x-12.406 y-3.437
    x-12.439 y-3.389
    x-12.472 y-3.34
    x-12.505 y-3.291
    x-12.537 y-3.242
    x-12.569 y-3.192
    x-12.6 y-3.142
    x-12.631 y-3.093
    x-12.662 y-3.042
    x-12.693 y-2.992
    x-12.723 y-2.942
    x-12.752 y-2.891
    x-12.782 y-2.84
    x-12.81 y-2.788
    x-12.839 y-2.737
    x-12.867 y-2.685
    x-12.895 y-2.634
    x-12.922 y-2.581
    x-12.949 y-2.529
    x-12.976 y-2.477
    x-13.002 y-2.424
    x-13.028 y-2.371
    x-13.053 y-2.318
    x-13.079 y-2.265
    x-13.103 y-2.212
    x-13.128 y-2.158
    x-13.151 y-2.104
    x-13.175 y-2.05
    x-13.198 y-1.996
    x-13.221 y-1.942
    x-13.243 y-1.888
    x-13.265 y-1.833
    x-13.286 y-1.778
    x-13.308 y-1.723
    x-13.328 y-1.668
    x-13.349 y-1.613
    x-13.368 y-1.558
    x-13.388 y-1.502
    x-13.407 y-1.447
    x-13.426 y-1.391
    x-13.444 y-1.335
    x-13.462 y-1.279
    x-13.479 y-1.223
    x-13.496 y-1.166
    x-13.513 y-1.11
    x-13.529 y-1.053
    x-13.545 y-0.997
    x-13.56 y-0.94
    x-13.575 y-0.883
    x-13.59 y-0.826
    x-13.604 y-0.769
    x-13.617 y-0.712
    x-13.631 y-0.654
    x-13.644 y-0.597
    x-13.656 y-0.539
    x-13.668 y-0.482
    x-13.68 y-0.424
    x-13.691 y-0.366
    x-13.701 y-0.309
    x-13.712 y-0.251
    x-13.722 y-0.193
    x-13.731 y-0.135
    x-13.74 y-0.077
    x-13.749 y-0.018
    x-13.757 y0.04
    x-13.765 y0.098
    x-13.772 y0.157
    x-13.779 y0.215
    x-13.785 y0.273
    x-13.791 y0.332
    x-13.797 y0.391
    x-13.802 y0.449
    x-13.807 y0.508
    x-13.811 y0.566
    x-13.815 y0.625
    x-13.819 y0.684
    x-13.822 y0.743
    x-13.824 y0.801
    x-13.826 y0.86
    x-13.828 y0.919
    x-13.829 y0.978
    x-13.83 y1.037
    x-13.831 y1.095
    y1.154
    x-13.83 y1.213
    x-13.829 y1.272
    x-13.828 y1.331
    x-13.826 y1.389
    x-13.824 y1.448
    x-13.822 y1.507
    x-13.819 y1.566
    x-13.815 y1.624
    x-13.811 y1.683
    x-13.807 y1.742
    x-13.802 y1.8
    x-13.797 y1.859
    x-13.791 y1.918
    x-13.785 y1.976
    x-13.779 y2.035
    x-13.772 y2.093
    x-13.765 y2.151
    x-13.757 y2.21
    x-13.749 y2.268
    x-13.74 y2.326
    x-13.731 y2.384
    x-13.722 y2.442
    x-13.712 y2.5
    x-13.701 y2.558
    x-13.691 y2.616
    x-13.68 y2.674
    x-13.668 y2.731
    x-13.656 y2.789
    x-13.644 y2.847
    x-13.631 y2.904
    x-13.617 y2.961
    x-13.604 y3.018
    x-13.59 y3.076
    x-13.575 y3.133
    x-13.56 y3.189
    x-13.545 y3.246
    x-13.529 y3.303
    x-13.513 y3.359
    x-13.496 y3.416
    x-13.479 y3.472
    x-13.462 y3.528
    x-13.444 y3.584
    x-13.426 y3.64
    x-13.407 y3.696
    x-13.388 y3.752
    x-13.368 y3.807
    x-13.349 y3.863
    x-13.328 y3.918
    x-13.308 y3.973
    x-13.286 y4.028
    x-13.265 y4.083
    x-13.243 y4.137
    x-13.221 y4.192
    x-13.198 y4.246
    x-13.175 y4.3
    x-13.151 y4.354
    x-13.128 y4.408
    x-13.103 y4.461
    x-13.079 y4.515
    x-13.053 y4.568
    x-13.028 y4.621
    x-13.002 y4.674
    x-12.976 y4.726
    x-12.949 y4.779
    x-12.922 y4.831
    x-12.895 y4.883
    x-12.867 y4.935
    x-12.839 y4.987
    x-12.81 y5.038
    x-12.782 y5.089
    x-12.752 y5.14
    x-12.723 y5.191
    x-12.693 y5.242
    x-12.662 y5.292
    x-12.631 y5.342
    x-12.6 y5.392
    x-12.569 y5.442
    x-12.537 y5.491
    x-12.505 y5.54
    x-12.472 y5.589
    x-12.439 y5.638
    x-12.406 y5.687
    x-12.372 y5.735
    x-12.338 y5.783
    x-12.304 y5.831
    x-12.269 y5.878
    x-12.234 y5.925
    x-12.199 y5.972
    x-12.163 y6.019
    x-12.127 y6.065
    x-12.09 y6.112
    x-12.054 y6.158
    x-12.017 y6.203
    x-11.979 y6.249
    x-11.941 y6.294
    x-11.903 y6.338
    x-11.865 y6.383
    x-11.826 y6.427
    x-11.787 y6.471
    x-11.748 y6.515
    x-11.708 y6.558
    x-11.668 y6.601
    x-11.627 y6.644
    x-11.587 y6.687
    x-11.546 y6.729
    x-11.505 y6.771
    x-11.463 y6.812
    x-11.421 y6.854
    x-11.379 y6.895
    x-11.336 y6.935
    x-11.294 y6.976
    x-11.25 y7.016
    x-11.207 y7.055
    x-11.163 y7.095
    x-11.119 y7.134
    x-11.075 y7.173
    x-11.031 y7.211
    x-10.986 y7.249
    x-10.941 y7.287
    x-10.895 y7.324
    x-10.85 y7.362
    x-10.804 y7.398
    x-10.758 y7.435
    x-10.711 y7.471
    x-10.665 y7.507
    x-10.618 y7.542
    x-10.57 y7.577
    x-10.523 y7.612
    x-10.475 y7.646
    x-10.427 y7.68
    x-10.379 y7.714
    x-10.33 y7.747
    x-10.282 y7.78
    x-10.233 y7.813
    x-10.184 y7.845
    x-10.134 y7.877
    x-10.084 y7.908
    x-10.035 y7.94
    x-9.984 y7.97
    x-9.934 y8.001
    x-9.884 y8.031
    x-9.833 y8.06
    x-9.782 y8.09
    x-9.73 y8.119
    x-9.679 y8.147
    x-9.627 y8.175
    x-9.576 y8.203
    x-9.524 y8.231
    x-9.471 y8.258
    x-9.419 y8.284
    x-9.366 y8.311
    x-9.313 y8.336
    x-9.26 y8.362
    x-9.207 y8.387
    x-9.154 y8.412
    x-9.1 y8.436
    x-9.046 y8.46
    x-8.992 y8.483
    x-8.938 y8.506
    x-8.884 y8.529
    x-8.83 y8.552
    x-8.775 y8.573
    x-8.748 y8.584
    g3 x-7.806 y9.966 i-0.543 j1.382
    g1 y10.998
    g2 x-7.509 y11.295 i0.297 j0.
    G1 x-7.212
    g18 g2 x-6.915 z2.997 i0. K0.297
    g0 z19.
    X-4.654 y3.615
    z8.
    G1 z4.3 f333.
    Z2.997
    x-4.652 y3.612 z2.951
    x-4.645 y3.604 z2.905
    x-4.634 y3.59 z2.862
    x-4.619 y3.571 z2.822
    x-4.6 y3.547 z2.787
    x-4.577 y3.52 z2.757
    x-4.552 y3.489 z2.732
    x-4.525 y3.455 z2.715
    x-4.497 y3.42 z2.704
    x-4.468 y3.384 z2.7
    x-4.281 y3.153 f1000.
    G17 g2 x-4.326 y2.735 i-0.231 j-0.186
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    g3 x2.148 y-12.173 i4.485 j0.
    G1 x27.361
    y-12.418
    g3 x29.346 y-14.403 i1.985 j0.
    G1 x32.834
    y-15.008
    g3 x34.319 y-16.493 i1.485 j0.
    G1 x35.319
    g3 x50.804 y-1.008 i0. J15.485
    x35.319 y14.477 i-15.485 j0.
    G1 x34.319
    g3 x32.834 y12.992 i0. J-1.485
    g1 y12.919
    x29.319
    g3 x27.334 y10.934 i0. J-1.985
    g1 y10.397
    x2.148
    g3 x-2.337 y5.912 i0. J-4.485
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g2 x-4.744 y2.78 i-0.186 j0.231
    g1 x-4.93 y3.011
    x-4.959 y3.047 z2.704
    x-4.988 y3.082 z2.715
    x-5.015 y3.116 z2.732
    x-5.04 y3.147 z2.757
    x-5.062 y3.174 z2.787
    x-5.081 y3.198 z2.822
    x-5.096 y3.217 z2.862
    x-5.107 y3.231 z2.905
    x-5.114 y3.239 z2.951
    x-5.117 y3.242 z2.997
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z4.3 f333.
    Z2.997
    x-8.078 y7.906 z2.951
    x-8.085 y7.914 z2.905
    x-8.096 y7.929 z2.862
    x-8.111 y7.948 z2.822
    x-8.129 y7.972 z2.787
    x-8.151 y8. Z2.757
    x-8.175 y8.031 z2.732
    x-8.201 y8.065 z2.715
    x-8.229 y8.101 z2.704
    x-8.257 y8.138 z2.7
    x-8.439 y8.373 f1000.
    G2 x-8.385 y8.79 i0.235 j0.181
    g3 x-7.877 y9.513 i-0.906 j1.176
    g1 x-6.812
    g3 x-4.327 y11.998 i0. J2.485
    g1 y15.008
    g3 x-5.812 y16.493 i-1.485 j0.
    G1 x-49.319
    g3 x-50.804 y15.008 i0. J-1.485
    g1 y-12.992
    g3 x-49.319 y-14.477 i1.485 j0.
    G1 x-5.812
    g3 x-4.327 y-12.992 i0. J1.485
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g3 x-6.812 y-7.259 i-2.477 j-0.204
    g1 x-7.878
    g3 x-8.748 y-6.335 i-1.413 j-0.458
    g2 y8.584 i2.932 j7.459
    g3 x-8.385 y8.79 i-0.543 j1.382
    g2 x-7.968 y8.736 i0.181 j-0.235
    g1 x-7.787 y8.501
    x-7.758 y8.464 z2.704
    x-7.731 y8.428 z2.715
    x-7.705 y8.394 z2.732
    x-7.68 y8.362 z2.757
    x-7.659 y8.334 z2.787
    x-7.64 y8.31 z2.822
    x-7.625 y8.291 z2.862
    x-7.614 y8.277 z2.905
    x-7.608 y8.268 z2.951
    x-7.606 y8.265 z2.997
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z4. F333.
    Z2.697
    x-8.078 y7.906 z2.651
    x-8.085 y7.914 z2.605
    x-8.096 y7.929 z2.562
    x-8.111 y7.948 z2.522
    x-8.129 y7.972 z2.487
    x-8.151 y8. Z2.457
    x-8.175 y8.031 z2.432
    x-8.201 y8.065 z2.415
    x-8.229 y8.101 z2.404
    x-8.257 y8.138 z2.4
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z2.404
    x-7.731 y8.428 z2.415
    x-7.705 y8.394 z2.432
    x-7.68 y8.362 z2.457
    x-7.659 y8.334 z2.487
    x-7.64 y8.31 z2.522
    x-7.625 y8.291 z2.562
    x-7.614 y8.277 z2.605
    x-7.608 y8.268 z2.651
    x-7.606 y8.265 z2.697
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z4. F333.
    Z2.697
    x-4.652 y3.612 z2.651
    x-4.645 y3.604 z2.605
    x-4.634 y3.59 z2.562
    x-4.619 y3.571 z2.522
    x-4.6 y3.547 z2.487
    x-4.577 y3.52 z2.457
    x-4.552 y3.489 z2.432
    x-4.525 y3.455 z2.415
    x-4.497 y3.42 z2.404
    x-4.468 y3.384 z2.4
    G2 x-4.326 y2.735 i-0.231 j-0.186
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z2.404
    x-4.988 y3.082 z2.415
    x-5.015 y3.116 z2.432
    x-5.04 y3.147 z2.457
    x-5.062 y3.174 z2.487
    x-5.081 y3.198 z2.522
    x-5.096 y3.217 z2.562
    x-5.107 y3.231 z2.605
    x-5.114 y3.239 z2.651
    x-5.117 y3.242 z2.697
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z3.7 f333.
    Z2.397
    x-4.652 y3.612 z2.351
    x-4.645 y3.604 z2.305
    x-4.634 y3.59 z2.262
    x-4.619 y3.571 z2.222
    x-4.6 y3.547 z2.187
    x-4.577 y3.52 z2.157
    x-4.552 y3.489 z2.132
    x-4.525 y3.455 z2.115
    x-4.497 y3.42 z2.104
    x-4.468 y3.384 z2.1
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z2.104
    x-4.988 y3.082 z2.115
    x-5.015 y3.116 z2.132
    x-5.04 y3.147 z2.157
    x-5.062 y3.174 z2.187
    x-5.081 y3.198 z2.222
    x-5.096 y3.217 z2.262
    x-5.107 y3.231 z2.305
    x-5.114 y3.239 z2.351
    x-5.117 y3.242 z2.397
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z3.7 f333.
    Z2.397
    x-8.078 y7.906 z2.351
    x-8.085 y7.914 z2.305
    x-8.096 y7.929 z2.262
    x-8.111 y7.948 z2.222
    x-8.129 y7.972 z2.187
    x-8.151 y8. Z2.157
    x-8.175 y8.031 z2.132
    x-8.201 y8.065 z2.115
    x-8.229 y8.101 z2.104
    x-8.257 y8.138 z2.1
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z2.104
    x-7.731 y8.428 z2.115
    x-7.705 y8.394 z2.132
    x-7.68 y8.362 z2.157
    x-7.659 y8.334 z2.187
    x-7.64 y8.31 z2.222
    x-7.625 y8.291 z2.262
    x-7.614 y8.277 z2.305
    x-7.608 y8.268 z2.351
    x-7.606 y8.265 z2.397
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z3.4 f333.
    Z2.097
    x-8.078 y7.906 z2.051
    x-8.085 y7.914 z2.005
    x-8.096 y7.929 z1.962
    x-8.111 y7.948 z1.922
    x-8.129 y7.972 z1.887
    x-8.151 y8. Z1.857
    x-8.175 y8.031 z1.832
    x-8.201 y8.065 z1.815
    x-8.229 y8.101 z1.804
    x-8.257 y8.138 z1.8
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z1.804
    x-7.731 y8.428 z1.815
    x-7.705 y8.394 z1.832
    x-7.68 y8.362 z1.857
    x-7.659 y8.334 z1.887
    x-7.64 y8.31 z1.922
    x-7.625 y8.291 z1.962
    x-7.614 y8.277 z2.005
    x-7.608 y8.268 z2.051
    x-7.606 y8.265 z2.097
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z3.4 f333.
    Z2.097
    x-4.652 y3.612 z2.051
    x-4.645 y3.604 z2.005
    x-4.634 y3.59 z1.962
    x-4.619 y3.571 z1.922
    x-4.6 y3.547 z1.887
    x-4.577 y3.52 z1.857
    x-4.552 y3.489 z1.832
    x-4.525 y3.455 z1.815
    x-4.497 y3.42 z1.804
    x-4.468 y3.384 z1.8
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z1.804
    x-4.988 y3.082 z1.815
    x-5.015 y3.116 z1.832
    x-5.04 y3.147 z1.857
    x-5.062 y3.174 z1.887
    x-5.081 y3.198 z1.922
    x-5.096 y3.217 z1.962
    x-5.107 y3.231 z2.005
    x-5.114 y3.239 z2.051
    x-5.117 y3.242 z2.097
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z3.1 f333.
    Z1.797
    x-4.652 y3.612 z1.751
    x-4.645 y3.604 z1.705
    x-4.634 y3.59 z1.662
    x-4.619 y3.571 z1.622
    x-4.6 y3.547 z1.587
    x-4.577 y3.52 z1.557
    x-4.552 y3.489 z1.532
    x-4.525 y3.455 z1.515
    x-4.497 y3.42 z1.504
    x-4.468 y3.384 z1.5
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z1.504
    x-4.988 y3.082 z1.515
    x-5.015 y3.116 z1.532
    x-5.04 y3.147 z1.557
    x-5.062 y3.174 z1.587
    x-5.081 y3.198 z1.622
    x-5.096 y3.217 z1.662
    x-5.107 y3.231 z1.705
    x-5.114 y3.239 z1.751
    x-5.117 y3.242 z1.797
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z3.1 f333.
    Z1.797
    x-8.078 y7.906 z1.751
    x-8.085 y7.914 z1.705
    x-8.096 y7.929 z1.662
    x-8.111 y7.948 z1.622
    x-8.129 y7.972 z1.587
    x-8.151 y8. Z1.557
    x-8.175 y8.031 z1.532
    x-8.201 y8.065 z1.515
    x-8.229 y8.101 z1.504
    x-8.257 y8.138 z1.5
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z1.504
    x-7.731 y8.428 z1.515
    x-7.705 y8.394 z1.532
    x-7.68 y8.362 z1.557
    x-7.659 y8.334 z1.587
    x-7.64 y8.31 z1.622
    x-7.625 y8.291 z1.662
    x-7.614 y8.277 z1.705
    x-7.608 y8.268 z1.751
    x-7.606 y8.265 z1.797
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z2.8 f333.
    Z1.497
    x-8.078 y7.906 z1.451
    x-8.085 y7.914 z1.405
    x-8.096 y7.929 z1.362
    x-8.111 y7.948 z1.322
    x-8.129 y7.972 z1.287
    x-8.151 y8. Z1.257
    x-8.175 y8.031 z1.232
    x-8.201 y8.065 z1.215
    x-8.229 y8.101 z1.204
    x-8.257 y8.138 z1.2
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z1.204
    x-7.731 y8.428 z1.215
    x-7.705 y8.394 z1.232
    x-7.68 y8.362 z1.257
    x-7.659 y8.334 z1.287
    x-7.64 y8.31 z1.322
    x-7.625 y8.291 z1.362
    x-7.614 y8.277 z1.405
    x-7.608 y8.268 z1.451
    x-7.606 y8.265 z1.497
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z2.8 f333.
    Z1.497
    x-4.652 y3.612 z1.451
    x-4.645 y3.604 z1.405
    x-4.634 y3.59 z1.362
    x-4.619 y3.571 z1.322
    x-4.6 y3.547 z1.287
    x-4.577 y3.52 z1.257
    x-4.552 y3.489 z1.232
    x-4.525 y3.455 z1.215
    x-4.497 y3.42 z1.204
    x-4.468 y3.384 z1.2
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z1.204
    x-4.988 y3.082 z1.215
    x-5.015 y3.116 z1.232
    x-5.04 y3.147 z1.257
    x-5.062 y3.174 z1.287
    x-5.081 y3.198 z1.322
    x-5.096 y3.217 z1.362
    x-5.107 y3.231 z1.405
    x-5.114 y3.239 z1.451
    x-5.117 y3.242 z1.497
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z2.5 f333.
    Z1.197
    x-4.652 y3.612 z1.151
    x-4.645 y3.604 z1.105
    x-4.634 y3.59 z1.062
    x-4.619 y3.571 z1.022
    x-4.6 y3.547 z0.987
    x-4.577 y3.52 z0.957
    x-4.552 y3.489 z0.932
    x-4.525 y3.455 z0.915
    x-4.497 y3.42 z0.904
    x-4.468 y3.384 z0.9
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z0.904
    x-4.988 y3.082 z0.915
    x-5.015 y3.116 z0.932
    x-5.04 y3.147 z0.957
    x-5.062 y3.174 z0.987
    x-5.081 y3.198 z1.022
    x-5.096 y3.217 z1.062
    x-5.107 y3.231 z1.105
    x-5.114 y3.239 z1.151
    x-5.117 y3.242 z1.197
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z2.5 f333.
    Z1.197
    x-8.078 y7.906 z1.151
    x-8.085 y7.914 z1.105
    x-8.096 y7.929 z1.062
    x-8.111 y7.948 z1.022
    x-8.129 y7.972 z0.987
    x-8.151 y8. Z0.957
    x-8.175 y8.031 z0.932
    x-8.201 y8.065 z0.915
    x-8.229 y8.101 z0.904
    x-8.257 y8.138 z0.9
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z0.904
    x-7.731 y8.428 z0.915
    x-7.705 y8.394 z0.932
    x-7.68 y8.362 z0.957
    x-7.659 y8.334 z0.987
    x-7.64 y8.31 z1.022
    x-7.625 y8.291 z1.062
    x-7.614 y8.277 z1.105
    x-7.608 y8.268 z1.151
    x-7.606 y8.265 z1.197
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z2.2 f333.
    Z0.897
    x-8.078 y7.906 z0.851
    x-8.085 y7.914 z0.805
    x-8.096 y7.929 z0.762
    x-8.111 y7.948 z0.722
    x-8.129 y7.972 z0.687
    x-8.151 y8. Z0.657
    x-8.175 y8.031 z0.632
    x-8.201 y8.065 z0.615
    x-8.229 y8.101 z0.604
    x-8.257 y8.138 z0.6
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z0.604
    x-7.731 y8.428 z0.615
    x-7.705 y8.394 z0.632
    x-7.68 y8.362 z0.657
    x-7.659 y8.334 z0.687
    x-7.64 y8.31 z0.722
    x-7.625 y8.291 z0.762
    x-7.614 y8.277 z0.805
    x-7.608 y8.268 z0.851
    x-7.606 y8.265 z0.897
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z2.2 f333.
    Z0.897
    x-4.652 y3.612 z0.851
    x-4.645 y3.604 z0.805
    x-4.634 y3.59 z0.762
    x-4.619 y3.571 z0.722
    x-4.6 y3.547 z0.687
    x-4.577 y3.52 z0.657
    x-4.552 y3.489 z0.632
    x-4.525 y3.455 z0.615
    x-4.497 y3.42 z0.604
    x-4.468 y3.384 z0.6
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z0.604
    x-4.988 y3.082 z0.615
    x-5.015 y3.116 z0.632
    x-5.04 y3.147 z0.657
    x-5.062 y3.174 z0.687
    x-5.081 y3.198 z0.722
    x-5.096 y3.217 z0.762
    x-5.107 y3.231 z0.805
    x-5.114 y3.239 z0.851
    x-5.117 y3.242 z0.897
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z1.9 f333.
    Z0.597
    x-4.652 y3.612 z0.551
    x-4.645 y3.604 z0.505
    x-4.634 y3.59 z0.462
    x-4.619 y3.571 z0.422
    x-4.6 y3.547 z0.387
    x-4.577 y3.52 z0.357
    x-4.552 y3.489 z0.332
    x-4.525 y3.455 z0.315
    x-4.497 y3.42 z0.304
    x-4.468 y3.384 z0.3
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z0.304
    x-4.988 y3.082 z0.315
    x-5.015 y3.116 z0.332
    x-5.04 y3.147 z0.357
    x-5.062 y3.174 z0.387
    x-5.081 y3.198 z0.422
    x-5.096 y3.217 z0.462
    x-5.107 y3.231 z0.505
    x-5.114 y3.239 z0.551
    x-5.117 y3.242 z0.597
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z1.9 f333.
    Z0.597
    x-8.078 y7.906 z0.551
    x-8.085 y7.914 z0.505
    x-8.096 y7.929 z0.462
    x-8.111 y7.948 z0.422
    x-8.129 y7.972 z0.387
    x-8.151 y8. Z0.357
    x-8.175 y8.031 z0.332
    x-8.201 y8.065 z0.315
    x-8.229 y8.101 z0.304
    x-8.257 y8.138 z0.3
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z0.304
    x-7.731 y8.428 z0.315
    x-7.705 y8.394 z0.332
    x-7.68 y8.362 z0.357
    x-7.659 y8.334 z0.387
    x-7.64 y8.31 z0.422
    x-7.625 y8.291 z0.462
    x-7.614 y8.277 z0.505
    x-7.608 y8.268 z0.551
    x-7.606 y8.265 z0.597
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z1.6 f333.
    Z0.297
    x-8.078 y7.906 z0.251
    x-8.085 y7.914 z0.205
    x-8.096 y7.929 z0.162
    x-8.111 y7.948 z0.122
    x-8.129 y7.972 z0.087
    x-8.151 y8. Z0.057
    x-8.175 y8.031 z0.032
    x-8.201 y8.065 z0.015
    x-8.229 y8.101 z0.004
    x-8.257 y8.138 z0.
    X-8.439 y8.373 f1000.
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z0.004
    x-7.731 y8.428 z0.015
    x-7.705 y8.394 z0.032
    x-7.68 y8.362 z0.057
    x-7.659 y8.334 z0.087
    x-7.64 y8.31 z0.122
    x-7.625 y8.291 z0.162
    x-7.614 y8.277 z0.205
    x-7.608 y8.268 z0.251
    x-7.606 y8.265 z0.297
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z1.6 f333.
    Z0.297
    x-4.652 y3.612 z0.251
    x-4.645 y3.604 z0.205
    x-4.634 y3.59 z0.162
    x-4.619 y3.571 z0.122
    x-4.6 y3.547 z0.087
    x-4.577 y3.52 z0.057
    x-4.552 y3.489 z0.032
    x-4.525 y3.455 z0.015
    x-4.497 y3.42 z0.004
    x-4.468 y3.384 z0.
    X-4.281 y3.153 f1000.
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z0.004
    x-4.988 y3.082 z0.015
    x-5.015 y3.116 z0.032
    x-5.04 y3.147 z0.057
    x-5.062 y3.174 z0.087
    x-5.081 y3.198 z0.122
    x-5.096 y3.217 z0.162
    x-5.107 y3.231 z0.205
    x-5.114 y3.239 z0.251
    x-5.117 y3.242 z0.297
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z1.3 f333.
    Z-0.003
    x-4.652 y3.612 z-0.049
    x-4.645 y3.604 z-0.095
    x-4.634 y3.59 z-0.138
    x-4.619 y3.571 z-0.178
    x-4.6 y3.547 z-0.213
    x-4.577 y3.52 z-0.243
    x-4.552 y3.489 z-0.268
    x-4.525 y3.455 z-0.285
    x-4.497 y3.42 z-0.296
    x-4.468 y3.384 z-0.3
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-0.296
    x-4.988 y3.082 z-0.285
    x-5.015 y3.116 z-0.268
    x-5.04 y3.147 z-0.243
    x-5.062 y3.174 z-0.213
    x-5.081 y3.198 z-0.178
    x-5.096 y3.217 z-0.138
    x-5.107 y3.231 z-0.095
    x-5.114 y3.239 z-0.049
    x-5.117 y3.242 z-0.003
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z1.3 f333.
    Z-0.003
    x-8.078 y7.906 z-0.049
    x-8.085 y7.914 z-0.095
    x-8.096 y7.929 z-0.138
    x-8.111 y7.948 z-0.178
    x-8.129 y7.972 z-0.213
    x-8.151 y8. Z-0.243
    x-8.175 y8.031 z-0.268
    x-8.201 y8.065 z-0.285
    x-8.229 y8.101 z-0.296
    x-8.257 y8.138 z-0.3
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-0.296
    x-7.731 y8.428 z-0.285
    x-7.705 y8.394 z-0.268
    x-7.68 y8.362 z-0.243
    x-7.659 y8.334 z-0.213
    x-7.64 y8.31 z-0.178
    x-7.625 y8.291 z-0.138
    x-7.614 y8.277 z-0.095
    x-7.608 y8.268 z-0.049
    x-7.606 y8.265 z-0.003
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z1. F333.
    Z-0.303
    x-8.078 y7.906 z-0.349
    x-8.085 y7.914 z-0.395
    x-8.096 y7.929 z-0.438
    x-8.111 y7.948 z-0.478
    x-8.129 y7.972 z-0.513
    x-8.151 y8. Z-0.543
    x-8.175 y8.031 z-0.568
    x-8.201 y8.065 z-0.585
    x-8.229 y8.101 z-0.596
    x-8.257 y8.138 z-0.6
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-0.596
    x-7.731 y8.428 z-0.585
    x-7.705 y8.394 z-0.568
    x-7.68 y8.362 z-0.543
    x-7.659 y8.334 z-0.513
    x-7.64 y8.31 z-0.478
    x-7.625 y8.291 z-0.438
    x-7.614 y8.277 z-0.395
    x-7.608 y8.268 z-0.349
    x-7.606 y8.265 z-0.303
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z1. F333.
    Z-0.303
    x-4.652 y3.612 z-0.349
    x-4.645 y3.604 z-0.395
    x-4.634 y3.59 z-0.438
    x-4.619 y3.571 z-0.478
    x-4.6 y3.547 z-0.513
    x-4.577 y3.52 z-0.543
    x-4.552 y3.489 z-0.568
    x-4.525 y3.455 z-0.585
    x-4.497 y3.42 z-0.596
    x-4.468 y3.384 z-0.6
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-0.596
    x-4.988 y3.082 z-0.585
    x-5.015 y3.116 z-0.568
    x-5.04 y3.147 z-0.543
    x-5.062 y3.174 z-0.513
    x-5.081 y3.198 z-0.478
    x-5.096 y3.217 z-0.438
    x-5.107 y3.231 z-0.395
    x-5.114 y3.239 z-0.349
    x-5.117 y3.242 z-0.303
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z0.7 f333.
    Z-0.603
    x-4.652 y3.612 z-0.649
    x-4.645 y3.604 z-0.695
    x-4.634 y3.59 z-0.738
    x-4.619 y3.571 z-0.778
    x-4.6 y3.547 z-0.813
    x-4.577 y3.52 z-0.843
    x-4.552 y3.489 z-0.868
    x-4.525 y3.455 z-0.885
    x-4.497 y3.42 z-0.896
    x-4.468 y3.384 z-0.9
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-0.896
    x-4.988 y3.082 z-0.885
    x-5.015 y3.116 z-0.868
    x-5.04 y3.147 z-0.843
    x-5.062 y3.174 z-0.813
    x-5.081 y3.198 z-0.778
    x-5.096 y3.217 z-0.738
    x-5.107 y3.231 z-0.695
    x-5.114 y3.239 z-0.649
    x-5.117 y3.242 z-0.603
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z0.7 f333.
    Z-0.603
    x-8.078 y7.906 z-0.649
    x-8.085 y7.914 z-0.695
    x-8.096 y7.929 z-0.738
    x-8.111 y7.948 z-0.778
    x-8.129 y7.972 z-0.813
    x-8.151 y8. Z-0.843
    x-8.175 y8.031 z-0.868
    x-8.201 y8.065 z-0.885
    x-8.229 y8.101 z-0.896
    x-8.257 y8.138 z-0.9
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-0.896
    x-7.731 y8.428 z-0.885
    x-7.705 y8.394 z-0.868
    x-7.68 y8.362 z-0.843
    x-7.659 y8.334 z-0.813
    x-7.64 y8.31 z-0.778
    x-7.625 y8.291 z-0.738
    x-7.614 y8.277 z-0.695
    x-7.608 y8.268 z-0.649
    x-7.606 y8.265 z-0.603
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z0.4 f333.
    Z-0.903
    x-8.078 y7.906 z-0.949
    x-8.085 y7.914 z-0.995
    x-8.096 y7.929 z-1.038
    x-8.111 y7.948 z-1.078
    x-8.129 y7.972 z-1.113
    x-8.151 y8. Z-1.143
    x-8.175 y8.031 z-1.168
    x-8.201 y8.065 z-1.185
    x-8.229 y8.101 z-1.196
    x-8.257 y8.138 z-1.2
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-1.196
    x-7.731 y8.428 z-1.185
    x-7.705 y8.394 z-1.168
    x-7.68 y8.362 z-1.143
    x-7.659 y8.334 z-1.113
    x-7.64 y8.31 z-1.078
    x-7.625 y8.291 z-1.038
    x-7.614 y8.277 z-0.995
    x-7.608 y8.268 z-0.949
    x-7.606 y8.265 z-0.903
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z0.4 f333.
    Z-0.903
    x-4.652 y3.612 z-0.949
    x-4.645 y3.604 z-0.995
    x-4.634 y3.59 z-1.038
    x-4.619 y3.571 z-1.078
    x-4.6 y3.547 z-1.113
    x-4.577 y3.52 z-1.143
    x-4.552 y3.489 z-1.168
    x-4.525 y3.455 z-1.185
    x-4.497 y3.42 z-1.196
    x-4.468 y3.384 z-1.2
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-1.196
    x-4.988 y3.082 z-1.185
    x-5.015 y3.116 z-1.168
    x-5.04 y3.147 z-1.143
    x-5.062 y3.174 z-1.113
    x-5.081 y3.198 z-1.078
    x-5.096 y3.217 z-1.038
    x-5.107 y3.231 z-0.995
    x-5.114 y3.239 z-0.949
    x-5.117 y3.242 z-0.903
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z0.1 f333.
    Z-1.203
    x-4.652 y3.612 z-1.249
    x-4.645 y3.604 z-1.295
    x-4.634 y3.59 z-1.338
    x-4.619 y3.571 z-1.378
    x-4.6 y3.547 z-1.413
    x-4.577 y3.52 z-1.443
    x-4.552 y3.489 z-1.468
    x-4.525 y3.455 z-1.485
    x-4.497 y3.42 z-1.496
    x-4.468 y3.384 z-1.5
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-1.496
    x-4.988 y3.082 z-1.485
    x-5.015 y3.116 z-1.468
    x-5.04 y3.147 z-1.443
    x-5.062 y3.174 z-1.413
    x-5.081 y3.198 z-1.378
    x-5.096 y3.217 z-1.338
    x-5.107 y3.231 z-1.295
    x-5.114 y3.239 z-1.249
    x-5.117 y3.242 z-1.203
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z0.1 f333.
    Z-1.203
    x-8.078 y7.906 z-1.249
    x-8.085 y7.914 z-1.295
    x-8.096 y7.929 z-1.338
    x-8.111 y7.948 z-1.378
    x-8.129 y7.972 z-1.413
    x-8.151 y8. Z-1.443
    x-8.175 y8.031 z-1.468
    x-8.201 y8.065 z-1.485
    x-8.229 y8.101 z-1.496
    x-8.257 y8.138 z-1.5
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-1.496
    x-7.731 y8.428 z-1.485
    x-7.705 y8.394 z-1.468
    x-7.68 y8.362 z-1.443
    x-7.659 y8.334 z-1.413
    x-7.64 y8.31 z-1.378
    x-7.625 y8.291 z-1.338
    x-7.614 y8.277 z-1.295
    x-7.608 y8.268 z-1.249
    x-7.606 y8.265 z-1.203
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z-0.2 f333.
    Z-1.503
    x-8.078 y7.906 z-1.549
    x-8.085 y7.914 z-1.595
    x-8.096 y7.929 z-1.638
    x-8.111 y7.948 z-1.678
    x-8.129 y7.972 z-1.713
    x-8.151 y8. Z-1.743
    x-8.175 y8.031 z-1.768
    x-8.201 y8.065 z-1.785
    x-8.229 y8.101 z-1.796
    x-8.257 y8.138 z-1.8
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-1.796
    x-7.731 y8.428 z-1.785
    x-7.705 y8.394 z-1.768
    x-7.68 y8.362 z-1.743
    x-7.659 y8.334 z-1.713
    x-7.64 y8.31 z-1.678
    x-7.625 y8.291 z-1.638
    x-7.614 y8.277 z-1.595
    x-7.608 y8.268 z-1.549
    x-7.606 y8.265 z-1.503
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z-0.2 f333.
    Z-1.503
    x-4.652 y3.612 z-1.549
    x-4.645 y3.604 z-1.595
    x-4.634 y3.59 z-1.638
    x-4.619 y3.571 z-1.678
    x-4.6 y3.547 z-1.713
    x-4.577 y3.52 z-1.743
    x-4.552 y3.489 z-1.768
    x-4.525 y3.455 z-1.785
    x-4.497 y3.42 z-1.796
    x-4.468 y3.384 z-1.8
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-1.796
    x-4.988 y3.082 z-1.785
    x-5.015 y3.116 z-1.768
    x-5.04 y3.147 z-1.743
    x-5.062 y3.174 z-1.713
    x-5.081 y3.198 z-1.678
    x-5.096 y3.217 z-1.638
    x-5.107 y3.231 z-1.595
    x-5.114 y3.239 z-1.549
    x-5.117 y3.242 z-1.503
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z-0.5 f333.
    Z-1.803
    x-4.652 y3.612 z-1.849
    x-4.645 y3.604 z-1.895
    x-4.634 y3.59 z-1.938
    x-4.619 y3.571 z-1.978
    x-4.6 y3.547 z-2.013
    x-4.577 y3.52 z-2.043
    x-4.552 y3.489 z-2.068
    x-4.525 y3.455 z-2.085
    x-4.497 y3.42 z-2.096
    x-4.468 y3.384 z-2.1
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-2.096
    x-4.988 y3.082 z-2.085
    x-5.015 y3.116 z-2.068
    x-5.04 y3.147 z-2.043
    x-5.062 y3.174 z-2.013
    x-5.081 y3.198 z-1.978
    x-5.096 y3.217 z-1.938
    x-5.107 y3.231 z-1.895
    x-5.114 y3.239 z-1.849
    x-5.117 y3.242 z-1.803
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z-0.5 f333.
    Z-1.803
    x-8.078 y7.906 z-1.849
    x-8.085 y7.914 z-1.895
    x-8.096 y7.929 z-1.938
    x-8.111 y7.948 z-1.978
    x-8.129 y7.972 z-2.013
    x-8.151 y8. Z-2.043
    x-8.175 y8.031 z-2.068
    x-8.201 y8.065 z-2.085
    x-8.229 y8.101 z-2.096
    x-8.257 y8.138 z-2.1
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-2.096
    x-7.731 y8.428 z-2.085
    x-7.705 y8.394 z-2.068
    x-7.68 y8.362 z-2.043
    x-7.659 y8.334 z-2.013
    x-7.64 y8.31 z-1.978
    x-7.625 y8.291 z-1.938
    x-7.614 y8.277 z-1.895
    x-7.608 y8.268 z-1.849
    x-7.606 y8.265 z-1.803
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z-0.8 f333.
    Z-2.103
    x-8.078 y7.906 z-2.149
    x-8.085 y7.914 z-2.195
    x-8.096 y7.929 z-2.238
    x-8.111 y7.948 z-2.278
    x-8.129 y7.972 z-2.313
    x-8.151 y8. Z-2.343
    x-8.175 y8.031 z-2.368
    x-8.201 y8.065 z-2.385
    x-8.229 y8.101 z-2.396
    x-8.257 y8.138 z-2.4
    g1 x-6.812
    g1 y15.008
    G1 x-49.319
    g1 y-12.992
    G1 x-5.812
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-2.396
    x-7.731 y8.428 z-2.385
    x-7.705 y8.394 z-2.368
    x-7.68 y8.362 z-2.343
    x-7.659 y8.334 z-2.313
    x-7.64 y8.31 z-2.278
    x-7.625 y8.291 z-2.238
    x-7.614 y8.277 z-2.195
    x-7.608 y8.268 z-2.149
    x-7.606 y8.265 z-2.103
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z-0.8 f333.
    Z-2.103
    x-4.652 y3.612 z-2.149
    x-4.645 y3.604 z-2.195
    x-4.634 y3.59 z-2.238
    x-4.619 y3.571 z-2.278
    x-4.6 y3.547 z-2.313
    x-4.577 y3.52 z-2.343
    x-4.552 y3.489 z-2.368
    x-4.525 y3.455 z-2.385
    x-4.497 y3.42 z-2.396
    x-4.468 y3.384 z-2.4
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x27.361
    y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x2.148
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-2.396
    x-4.988 y3.082 z-2.385
    x-5.015 y3.116 z-2.368
    x-5.04 y3.147 z-2.343
    x-5.062 y3.174 z-2.313
    x-5.081 y3.198 z-2.278
    x-5.096 y3.217 z-2.238
    x-5.107 y3.231 z-2.195
    x-5.114 y3.239 z-2.149
    x-5.117 y3.242 z-2.103
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z-1.1 f333.
    Z-2.403
    x-4.652 y3.612 z-2.449
    x-4.645 y3.604 z-2.495
    x-4.634 y3.59 z-2.538
    x-4.619 y3.571 z-2.578
    x-4.6 y3.547 z-2.613
    x-4.577 y3.52 z-2.643
    x-4.552 y3.489 z-2.668
    x-4.525 y3.455 z-2.685
    x-4.497 y3.42 z-2.696
    x-4.468 y3.384 z-2.7
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x15.889
    z-2.675
    x22.83
    z-2.7 f333.
    X27.361 f1000.
    Y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x15.267
    z-2.675
    x8.327
    z-2.7 f333.
    X2.148 f1000.
    G3 x-2.337 y5.912 i0. J-4.485
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-2.696
    x-4.988 y3.082 z-2.685
    x-5.015 y3.116 z-2.668
    x-5.04 y3.147 z-2.643
    x-5.062 y3.174 z-2.613
    x-5.081 y3.198 z-2.578
    x-5.096 y3.217 z-2.538
    x-5.107 y3.231 z-2.495
    x-5.114 y3.239 z-2.449
    x-5.117 y3.242 z-2.403
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z-1.1 f333.
    Z-2.403
    x-8.078 y7.906 z-2.449
    x-8.085 y7.914 z-2.495
    x-8.096 y7.929 z-2.538
    x-8.111 y7.948 z-2.578
    x-8.129 y7.972 z-2.613
    x-8.151 y8. Z-2.643
    x-8.175 y8.031 z-2.668
    x-8.201 y8.065 z-2.685
    x-8.229 y8.101 z-2.696
    x-8.257 y8.138 z-2.7
    g1 x-6.812
    g1 y15.008
    G1 x-12.387
    z-2.675
    x-19.327
    z-2.7 f333.
    X-49.319 f1000.
    G3 x-50.804 y15.008 i0. J-1.485
    g1 y-12.992
    G1 x-31.243
    z-2.675
    x-24.303
    z-2.7 f333.
    X-5.812 f1000.
    G3 x-4.327 y-12.992 i0. J1.485
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-2.696
    x-7.731 y8.428 z-2.685
    x-7.705 y8.394 z-2.668
    x-7.68 y8.362 z-2.643
    x-7.659 y8.334 z-2.613
    x-7.64 y8.31 z-2.578
    x-7.625 y8.291 z-2.538
    x-7.614 y8.277 z-2.495
    x-7.608 y8.268 z-2.449
    x-7.606 y8.265 z-2.403
    g0 z9.
    X-8.076 y7.903
    z8.
    G1 z-1.4 f333.
    Z-2.703
    x-8.078 y7.906 z-2.749
    x-8.085 y7.914 z-2.795
    x-8.096 y7.929 z-2.838
    x-8.111 y7.948 z-2.878
    x-8.129 y7.972 z-2.913
    x-8.151 y8. Z-2.943
    x-8.175 y8.031 z-2.968
    x-8.201 y8.065 z-2.985
    x-8.229 y8.101 z-2.996
    x-8.257 y8.138 z-3.
    g1 x-6.812
    g1 y15.008
    G1 x-12.387
    z-2.675
    x-19.327
    z-3. F333.
    X-49.319 f1000.
    g1 y-12.992
    G1 x-31.243
    z-2.675
    x-24.303
    z-3. F333.
    X-5.812 f1000.
    g1 y-9.748
    x-4.329 y-9.644
    x-4.336 y-9.54
    g1 x-7.878
    g1 x-7.787 y8.501
    x-7.758 y8.464 z-2.996
    x-7.731 y8.428 z-2.985
    x-7.705 y8.394 z-2.968
    x-7.68 y8.362 z-2.943
    x-7.659 y8.334 z-2.913
    x-7.64 y8.31 z-2.878
    x-7.625 y8.291 z-2.838
    x-7.614 y8.277 z-2.795
    x-7.608 y8.268 z-2.749
    x-7.606 y8.265 z-2.703
    g0 z9.
    X-4.654 y3.615
    z8.
    G1 z-1.4 f333.
    Z-2.703
    x-4.652 y3.612 z-2.749
    x-4.645 y3.604 z-2.795
    x-4.634 y3.59 z-2.838
    x-4.619 y3.571 z-2.878
    x-4.6 y3.547 z-2.913
    x-4.577 y3.52 z-2.943
    x-4.552 y3.489 z-2.968
    x-4.525 y3.455 z-2.985
    x-4.497 y3.42 z-2.996
    x-4.468 y3.384 z-3.
    g1 x-4.585 y2.526
    x-4.633 y2.486
    x-4.679 y2.443
    x-4.917 y2.216
    x-4.963 y2.169
    x-5.008 y2.121
    x-5.222 y1.876
    x-5.266 y1.822
    x-5.309 y1.766
    x-5.496 y1.506
    x-5.538 y1.444
    x-5.577 y1.381
    x-5.736 y1.105
    x-5.774 y1.036
    x-5.808 y0.964
    x-5.936 y0.675
    x-5.968 y0.598
    x-5.995 y0.519
    x-6.09 y0.217
    x-6.113 y0.133
    x-6.132 y0.047
    x-6.191 y-0.265
    x-6.202 y-0.332
    x-6.21 y-0.4
    x-6.225 y-0.56
    x-6.231 y-0.651
    x-6.236 y-0.814
    y-0.906
    x-6.232 y-1.07
    x-6.226 y-1.161
    x-6.211 y-1.323
    x-6.204 y-1.39
    x-6.193 y-1.457
    x-6.135 y-1.772
    x-6.116 y-1.858
    x-6.092 y-1.943
    x-5.998 y-2.246
    x-5.971 y-2.326
    x-5.939 y-2.404
    x-5.811 y-2.694
    x-5.777 y-2.766
    x-5.739 y-2.836
    x-5.581 y-3.112
    x-5.541 y-3.177
    x-5.499 y-3.239
    x-5.311 y-3.5
    x-5.269 y-3.556
    x-5.223 y-3.61
    x-5.009 y-3.855
    x-4.964 y-3.904
    x-4.917 y-3.951
    x-4.679 y-4.178
    x-4.632 y-4.22
    x-4.584 y-4.261
    x-4.325 y-4.469
    x-4.277 y-4.506
    x-4.227 y-4.541
    x-3.949 y-4.729
    x-3.9 y-4.761
    x-3.849 y-4.791
    x-3.555 y-4.957
    x-3.505 y-4.984
    x-3.453 y-5.01
    x-3.145 y-5.154
    x-3.093 y-5.177
    x-3.04 y-5.198
    x-2.72 y-5.319
    x-2.667 y-5.338
    x-2.612 y-5.355
    x-2.337 y-5.435
    y-7.688
    G1 x15.889
    z-2.675
    x22.83
    z-3. F333.
    X27.361 f1000.
    Y-12.418
    G1 x32.834
    y-15.008
    G1 x35.319
    G1 x34.319
    g1 y12.919
    x29.319
    g1 y10.397
    x15.267
    z-2.675
    x8.327
    z-3. F333.
    X2.148 f1000.
    g1 y3.709
    x-2.616 y3.627
    x-2.671 y3.61
    x-2.725 y3.59
    x-3.044 y3.469
    x-3.097 y3.447
    x-3.149 y3.424
    x-3.457 y3.278
    x-3.508 y3.253
    x-3.559 y3.225
    x-3.852 y3.058
    x-3.903 y3.028
    x-3.952 y2.996
    x-4.229 y2.807
    x-4.278 y2.772
    x-4.326 y2.735
    g1 x-4.93 y3.011
    x-4.959 y3.047 z-2.996
    x-4.988 y3.082 z-2.985
    x-5.015 y3.116 z-2.968
    x-5.04 y3.147 z-2.943
    x-5.062 y3.174 z-2.913
    x-5.081 y3.198 z-2.878
    x-5.096 y3.217 z-2.838
    x-5.107 y3.231 z-2.795
    x-5.114 y3.239 z-2.749
    x-5.117 y3.242 z-2.703
    g0 z19.
    G28 g91 z0.
    G90
    g28 g91 x0. Y0.
    G90
    m30
  9. #19
    sorry i didnt mean to post all the code, i have triedchangine my top height but that didnt make any difference at all which is strange, it is only doing on this peice i am working on, if i do a simple test pocket it cuts fine with the same fusion 360 height setup
  10. #20
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Richardtweed View Post
    You can edit the post to chop some of it out.
  1. Weird Mach3 + CSMIO/IP-M Probe Problem
    By matt-b2 in forum General Discussion
    Last Post: 11-07-2019, 01:05 PM
  2. help with filliting in fusion360
    By charlieuk in forum Fusion 360
    Last Post: 25-01-2017, 01:33 PM
  3. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  4. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
  5. Machine problem with softlimits mach3 & Estop
    By Steve-m in forum Artsoft Mach (3 & 4)
    Last Post: 12-01-2009, 05:38 PM
