26-09-2019 #21
Look at you Z values at the start of the code
G1 x-34.534
g17 g2 x-34.831 y1.008 i0. J0.297
x-18.801 z2.9 i8.015 j0.
X-34.831 z2.8 i-8.015 j0.
X-18.801 z2.7 i8.015 j0.
X-34.831 z2.6 i-8.015 j0.
It starts the cut at Z=2.9, unless you are setting your zero in Mach3 3mm below the surface of your stock then it's going to cut 3mm of air before it reaches the stock.You think that's too expensive? You're not a Model Engineer are you? :D
01-05-2022 #22
Hi Richard, I know it’s a long while but I’m having a similar issue to you, I home everything (xyz) then go to my material and zero (xy) creating a work home touch the z on the job and zero that and start the ‘cycle’ z goes up to home then comes down to make first cut but the zero is now reading about 2mm off the surface of the work, how has it re-zeroed itself! If you solved this can you share what you did. Many thanks Huw
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
help with filliting in fusion360
By charlieuk in forum Fusion 360Replies: 4Last Post: 25-01-2017, 01:33 PM -
Mach3 & V-Carve Problem
By Ricardoco in forum Computer SoftwareReplies: 2Last Post: 31-05-2013, 12:53 PM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM -
Machine problem with softlimits mach3 & Estop
By Steve-m in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 12-01-2009, 05:38 PM
