22-09-2019 #4
Sounds like it's your Cam (G-code) but unfortunately, I don't use F360 so can't help.
However, if you want to check your moving correct amounts regard steps per then Zero the work Coordinate then goto MDI type G0 Z10 (or any amount you prefer) then measure to see if it moved this amount. Then G0 Z0 and it should go back exactly to point you touch off at.
If this works then it's your Code.
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
help with filliting in fusion360
By charlieuk in forum Fusion 360Replies: 4Last Post: 25-01-2017, 01:33 PM -
Mach3 & V-Carve Problem
By Ricardoco in forum Computer SoftwareReplies: 2Last Post: 31-05-2013, 12:53 PM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM -
Machine problem with softlimits mach3 & Estop
By Steve-m in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 12-01-2009, 05:38 PM
