    Lives in East Lothian, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I normally use a 4 jaw chuck, along with 4 spacers so you can grip onto teeth without catching the flange.
    As for grub screw, if there's no wide enough boss, I normally just drill in the bottom between two teeth, then tap as required.
    Having machined some more yesterday, one more tip I omitted before: to get them central in the chuck, just shove a centre (live or dead) into the central hole: will also help with keeping it steady if the boss isn't very long.
    Thanks for the advice guys. Will give both a methods a try and let you know how in get on.
  1. can anybody near leicester bore out a cutter block?
    By danwhite in forum Metalwork Discussion
    Last Post: 14-10-2017, 02:08 PM
  2. cheap pilot arc plasma cutter
    By nobby in forum General Discussion
    Last Post: 15-05-2016, 10:13 PM
  3. FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
    By nobby in forum Items For Sale
    Last Post: 20-05-2014, 07:33 PM
  4. Need a perfect 8mm hole - to ream or bore?
    Last Post: 12-03-2013, 12:42 PM
  5. Increasing timing pulley bore size from 3mm t0 3.175mm
    By divdav in forum Gantry/Router Machines & Building
    Last Post: 14-05-2011, 09:45 AM
