28-09-2019 #2
Something wrong?
I'd guess it'll depend on all what the driver is capable off, and what settings can be changed via software.
Motor/wiring problem (does the drive sense motor wiring issues?), motor following error (there's a parameter for it...).
Have you got a copy of the 'simple commissioning manual' that's mentioned below the parameter table?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
29-09-2019 #3
29-09-2019 #4
I don`t know if this will help, it's a link to their product page
http://servo.xlichuan.com/prod_view....77&FId=t3:69:3
Andrew
30-09-2019 #5
Well, by chance I came across this page:
https://www.omc-stepperonline.com/cl...tor-cl57t.html
These drivers seem to be mechanically and electrically identical to the LIchuan parts other than the paint colour, branding and slightly smaller supply voltage range - if anyone has one of these it would be interesting to remove the cover and compare the PCB with the Lichuan part, I have a suspicion that they will be very similar knowing how things happen in China!. And there's a manual full of all sorts of good info you can download, and which has a very interesting typo in the last paragraph of page 5
06-10-2019 #6
Hi Voicecoil
The cl57t run with up to 8 amps. I think they are made by leadshine. I have 3 on order at the present time. I'll pop one open when they arrive if it's not to difficult and post a photo.
cheers
Andrew by the way if you order these as kits don't forget they come with cables, I didn't notice that and ordered some cables from their Belgian site. Oh well i'm sure i'll find a use for the wire or plugs
07-10-2019 #7
Closed loop stepper motor kit power supply
By the great waldo in forum Motor Drivers & ControllersReplies: 19Last Post: 21-09-2019, 10:08 AM -
Closed loop steppers vs servo ?
By threedee in forum Stepper & Servo MotorsReplies: 6Last Post: 29-06-2019, 01:00 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
