    That other DIP8 opto is also a 6N137, makes sense as although DIR won't change state as often as PULSE, there are setup times to be observed. Visual checking of the little white iso-optalator proved fruitless (hidden tracks) so I resorted to a DMM to bleep it through, and it appears to be connected to the enable input, albeit via a resistor or two. Peering underneath the board however there's another one however which I imagine does the alarm output, both those pins show >2Meg to ground, so are likely floating.
    Crafty buggers. Well, that answers your question as to the output drive capability.
    Hello chaps
    Here are a couple of photos of the stepperonline cl57T closed loop driver made by guess who. I hope its of interest. I got the kit with the nema 24 4nm motors the price difference with the 3 nm motor wasn't much and i'll be interested to get the machine together as i've had it lying around for months and am still using my old makko 850 machine with acme threads which makes horrible noises when pushed a bit.
    cheers
    AndrewClick image for larger version.
ID:	26491Click image for larger version.
    Thanks for that Andrew, the boards look pretty well identical apart from a couple of current sense resistors which are shorted out on the OMC - it would be interesting to know who copied who
  1. Closed loop stepper motor kit power supply
    By the great waldo in forum Motor Drivers & Controllers
    Last Post: 21-09-2019, 10:08 AM
  2. Closed loop steppers vs servo ?
    By threedee in forum Stepper & Servo Motors
    Last Post: 29-06-2019, 01:00 PM
  3. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  4. Testing Leadshine closed loop stepper system.
    By JAZZCNC in forum Stepper & Servo Motors
    Last Post: 13-10-2012, 05:39 PM
  5. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
