Thread: VFD cable article
From what I read it's more of 2 interleaved twisted triplets - a bit like 1.5x the starquad cable the BBC OB guys I worked with were so fond of in high noise situations. You might be right in that at 3x twisted pair would work better as far as EMI goes, it would all depend on the switching points of the VFD. However it would make the cable even more bulky and/or increase copper losses, so that's probably why it's not been done. It would be nice to investigate this further, but as no-one makes a 1mm2 such cable and it probably won't matter much on a 2.5m run, I have more important things to concentrate on.
I've already done this. The leads on the proximity sensors were woefully short, so had to be extended anyway, so I chopped them back to a sensible minimum length and extended with my favourite Mogami screened twisted pair cable. Why they don't make such sensors with a screened cable to start with I don't understand.While we're on about it, using a twisted pair rather than loose wires for connecting limit switches etc. to your BOB might help reject noise pickup even for non-balanced inputs.
Kit
05-10-2019 #2
Ha! Owning up to an Auntie connection now! I haven't heard about star quad since my earliest days as a trainee back at Wood Norton back when Noel Edmonds was a lad.
I'm sure the cable manufacturers are brainy enough to construct their products in a suitably 3-phase field-cancelling way.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
05-10-2019 #3
Back in the day I worked for a company supplying audio equipment to the Beeb, mostly for OB trucks, got to know one or two of their engineers quite well during the acceptance testing. I got to see some of the syllabus from the training courses at Wood Norton, very good stuff: when it got watered down/shut down/hived off it was a great loss to the industry IMHO.
Vfd cable
By D-man in forum Spindles & Drive MotorsReplies: 2Last Post: 29-06-2016, 01:23 PM -
Extending CY cable?
By Dwayne Dibbley in forum General ElectronicsReplies: 8Last Post: 11-03-2015, 08:33 PM -
cable prices
By deannos in forum Marketplace DiscussionReplies: 15Last Post: 10-12-2012, 10:25 PM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
FOR SALE: Cable Glands...
By Jimmybristol in forum Items For SaleReplies: 0Last Post: 07-02-2011, 07:33 PM
