08-10-2019 #11
Doddy: If you need help with this I have my Myford s7 running on linuxcnc but through a mesa card with 2 mpg's so I can use it manually.
I am also setting a lathe up for a forum member with a PP running linuxcnc with an encoder (just A + Z) for threading you need 2 pins on the PP for this so three left for homing switches if you need them (I don't bother)..Clive
08-10-2019 #12
Doddy,
Using parallel ports has to be on the way out, it's still a cheap starting option for amateurs but it can't last. Trouble is there are now several other options available at various price levels with no clear winner for the inexperienced to choose.Last edited by Kitwn; 08-10-2019 at 01:53 PM.
08-10-2019 #13
Clive, much appreciated, I might well bend your ear. Encoder = shaft encoder I take it?, that was my plan, with one limit switch to avoid crunching the stepper on the cross slide (I foolishly went for a low profile stepper on the rear of a mount plate instead of the jefree front mount and it will impact the handle for the split nut engage lever
08-10-2019 #14
08-10-2019 #15
And for those of us who only have ten shillings available for this specific part of the project, the seventeen-and-sixpence solution is not an option. And having now totally confused all of our non-UK readers and all of our under-50-yearold UK readers, I'm done for today.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
08-10-2019 #16
I actually made a 64 slot disc with slot opto sensors. https://photos.app.goo.gl/66KmdtD7TzUziNih7 you have to be able to move the sensors around to get the correct sync
edit: if I was to do it again I might have used a rotary encoder (it would have to be low count with a PP) But its been working for at least 3 - 4 years
https://photos.app.goo.gl/JH1GWVQbhxe6Z6Yo7 This is it simulating an arc that I needed to put on a roller for my belt sanderLast edited by Clive S; 08-10-2019 at 04:33 PM.
08-10-2019 #17
<sorry, tried to post elsewhere>
08-10-2019 #18
Yes sorry to the op
08-10-2019 #19
08-10-2019 #20
Check out the HP T510 thin client. It has a parallel port, has a dual core CPU that benchmarks twice as fast as my old XP machine, can be found with 16GB flash and according to parkytowers takes Linux well. There were one or two on the bay of fleas for £50 ish last time I looked.
There are currently 37 users browsing this thread. (0 members and 37 guests)
Windows 7 ~ Microsoft relents on shorter Windows 7 support decree
By AndyGuid in forum Computer SoftwareReplies: 4Last Post: 15-08-2016, 03:30 PM -
Machining thin Balsa
By Nthkentman in forum Woodwork DiscussionReplies: 3Last Post: 05-04-2015, 08:37 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
Step clamp design - Hold down thin or irregular shaped objects while milling!
By Lee Roberts in forum Programmers CornerReplies: 5Last Post: 15-04-2012, 12:36 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
