  1. #41
    That's kind of odd - you would have thought that with a thin client in it's intended role getting all it's data and apps from the central server decent ethernet would have been the first thing they'd get right.
  2. #42
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Light weight IRQ handling? I don’t know.
    As OP to this thread if you have the inclination to take this thread to a conclusion then I’d happily throw the 610 in your direction if you can source a W7CE install/licence. PM me if interested
  3. #43
    Well I've been using the machine for real for something like 4 weeks now, so thought I ought to report on what I ended up with computer-wise. My original plan to run UCCNC on the HP610 that Doddy kindly gifted me (or an old Dell I had knocking about) came to nowt as they wouldn't support the version of open GL that the latest version of UCCNC uses, so I swapped out for the Dell/Wyse D90D7 I was using to run my audio test gear (£30 from the Bay of fleas). Some probing about revealed that you can't easily get these devices to run any other version of Windoze apart from what they came with, so I set about trying to make it work on Windoze CES7. I deleted all the networking stuff and had a few fights with the FBWF (File Based Write Filter) that's used when it's a thin client, but after that it seems to work pretty well. To change anything you have to log in as Admin, but when it comes to actual machining, I just turn it on and plug in a USB stick with the G code files. If I wasn't working remotely from my design PC I's have had a shot at networking it, but since they're 3 miles apart we'll leave that for a bit.
  4. #44
    Doddy's Avatar
    Interesting write-up - I think we all like the idea of a dedicated, small, contained (and in my case, cheap) controller. Something that doesn't bugger off on a 2 week vacation whilst it updates to the latest and greatest patch.
    I have to admit that I don't practise what I preach and I prefer a machine that I can CAD/CAM and machine as an all-in-one, simply I do not have the space for multiple monitors, keyboards and mice (even now I'm behind KVMs for linux and windows with a WAN and two LANs for the two separate machine controllers).
    Just a thought - and I'm showing my ignorance for CE - is there no general "config" file used to configure what is supposed to be a deployable embedded system - that you could offer as a starter-for-ten for others here that may want to use a similar thin client? (I'm thinking if the settings are held in a single file, rather than the usual bloated windows registry crap.
    EDIT: "gifted"?, hardly, we came to an arrangement that you honoured.
  5. #45
    Well, I spent a bit of time looking into that side of things - being a bit perfectionist I wanted to slim down the Windoze Compact Embedded (WCE) as much as possible - but didn't really manage to sort it. It appears you're largely stuck with what you've got, the only way to thoroughly customise it is to create your own WCE image which you then install that can have as few or as many features as you want. To do that requires a development kit, one day if I'm feeling brave and with a lot of time to kill I might just give Microsoft a buzz and find out how you get one, however I can't help but feel it will be expensive.
    PS there seem to be some 3rd party developers doing development kits which might be worth a look at too. With WCE7 coming to end of life in 2021, there might be something going cheap?
    PPS Another thing I discovered is that WCE (unlike NT based versions) is a real time OS.
    Yes, with all the chaos of the last few weeks I'd forgotten that - but it was a generous arrangement and I thank you for it.
  6. #46
    You can easily do this using Windows. Compatible with DOS applications. Working in a Windows environment does not force you to give up using DOS programs. Moreover, to run DOS programs, as a rule, there is no need to exit Windows. However, DOS programs running Windows are slower. By the way, what I like about Windows is that it is absolutely unpretentious in terms of licenses. You can always find even Windows activation keys. For example, using a website mysoftwarekeys.com . I hope this information will help you.
  7. #47
    I found your write-up on repurposing a thin client PC quite interesting. I totally get the appeal of having a dedicated, compact, and cost-effective controller that doesn't go on vacation for software updates! Personally, I prefer an all-in-one machine for CAD/CAM purposes, considering the space constraints.
    Regarding the configuration of embedded systems, I'm not an expert, but I think it would be great if there were a general "config" file that could simplify the process for others. Maybe someone in this forum knows more about it and can offer some insights.
    Have you checked out the Reddit sub that discusses various Windows-related topics? They might have some helpful information for you. It's a great community to connect with fellow Windows enthusiasts.
  1. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  2. Machining thin Balsa
    By Nthkentman in forum Woodwork Discussion
    Last Post: 05-04-2015, 08:37 PM
  3. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  4. Replies: 5
    Last Post: 15-04-2012, 12:36 PM
  5. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
