Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    If you're looking to put Linux on a thin client PC, then there's quite a bit of useful info. here:
    https://www.parkytowers.me.uk/thin/
    ... just wish I had the time to properly learn a new OS
  2. #32
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    Just wish I had the available memory to properly learn ANY OS!
    Glad you got your thread back, but it's been a very informative exchange.
    Kit
  3. #33
    That would be cool, thanks.
    Dammit!, the box is literally straight from a (corporate) install - it's trying to logon to their CE network servers, prompting for login/password credentials. I don't think I'm going to be able to pull anything together re. a Win7CE install.
  4. #34
    Does it seem to be running Windoze? if so you might be get round it by logging in as administrator - a quick google should pull up the default password. What you've got seems to be fairly common, there's info. out there for how to get round it and put on a new OS.
  5. #35
    I can get a new OS on okay, it's trialling UCCNC on W7CE (native install) that's problematic
  6. #36
    Experience so far, dry-fitting a LinuxCNC install. Wheezy (Debian 7 based) has the latency test spiking around 130us, and Stetch (Debian 9) around 180us. Looking at the graphs these are frequent large spikes (circa 1-second, short duration - interrupts? but seemingly random in nature) against a baseline of around 20us. I've looked at SMI and power management - no gains there, and similarly with disconnecting Ethernet and WiFi. Under Wheezy I couldn't get WiFi operation (and it's too archaic to be a comfortable installation). Upgraded 4GB ram to 8GB ram under Stretch with no improvement (though general usage feels better).
    Beautiful, small form-factor - the T610Plus is a nice, silent and cool running PC (the fan on a Raspberry Pi 4 drowns out the HP), good connectivity, but not good real-time performance out-of-the-box.
    Having scrimped on this, I've now had to spend £300 on a 7176e card to support (though that's as much for the I/O that I want for MPGs and spindle encoders) - I don't think there was much mileage in using the PP for this. Of course, for a linux buff, if you can set core-affinities to OS/interrupts onto one core and LinuxCNC onto the second - your results may vary.
  7. #37
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think Stretch is the preferred version for Mesa cards.
    http://linuxcnc.org/downloads/
  8. #38
    Clive - Cheers - clearly I shouldn't write early in the morning - I meant Stretch (not Squeeze) - I've amended the post above.
  9. #39
    That's cool, didn't realise you could do stuff like that.
  10. #40
    Okay, perhaps a little premature but this is the first day that I've had a controller wired-up (standalone stepper), the Mesa 7i76E and the thin-client (T610 plus, 8GB memory).
    I knew the latency test was a bit mheh!, averaging around 200us but figured having an Ethernet motion controller would offset that. Prior to this I'd been doing all the Debian updates, updates to non-free graphic drivers, increasing system memory, and following as many (diverse!) opinions on tuning a LinuxCNC installation as I could as well as disabling all power-management under the BIOS. Now, this was the first time I've had to configure an interface (previously ran under the simulation mode for familiarisation), but in a nut-shell... it's pants! Frequent error messages through through what appears to be loss of ethernet packets. I've tried point-to-point as well as through a standalone switch - I can run from seconds to minutes, but ultimately it fails.
    Still treading carefully on new territory for me, I've reconfigured an old XP box (Viglen Genie - great little boxes) previously used for Mach/PP/Ethernet to LinuxCNC (latest, and same install as the thin client). 40 minutes later I've got rock-solid performance and latency in the 3-6us range.
    Perhaps will a bit of tlc the thin client is a possibility, but facing a number of learning curves at this time I'm taking it off the table for now and sticking with a standard machine, which, thinking about it, cost less than the thin client and is only marginally larger.
    Your experience may vary.
    EDIT:
    For S&Gs, if I get time this afternoon I might try walking the path of getting LinuxCNC onto a RaspPi4 that's otherwise collecting dust.
  1. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  2. Machining thin Balsa
    By Nthkentman in forum Woodwork Discussion
    Last Post: 05-04-2015, 08:37 PM
  3. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  4. Replies: 5
    Last Post: 15-04-2012, 12:36 PM
  5. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
