    You can easily do this using Windows. Compatible with DOS applications. Working in a Windows environment does not force you to give up using DOS programs. Moreover, to run DOS programs, as a rule, there is no need to exit Windows. However, DOS programs running Windows are slower. By the way, what I like about Windows is that it is absolutely unpretentious in terms of licenses. You can always find even Windows activation keys. For example, using a website mysoftwarekeys.com . I hope this information will help you.
    I found your write-up on repurposing a thin client PC quite interesting. I totally get the appeal of having a dedicated, compact, and cost-effective controller that doesn't go on vacation for software updates! Personally, I prefer an all-in-one machine for CAD/CAM purposes, considering the space constraints.
    Regarding the configuration of embedded systems, I'm not an expert, but I think it would be great if there were a general "config" file that could simplify the process for others. Maybe someone in this forum knows more about it and can offer some insights.
    Have you checked out the Reddit sub that discusses various Windows-related topics? They might have some helpful information for you. It's a great community to connect with fellow Windows enthusiasts.
  1. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  2. Machining thin Balsa
    By Nthkentman in forum Woodwork Discussion
    Last Post: 05-04-2015, 08:37 PM
  3. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  4. Replies: 5
    Last Post: 15-04-2012, 12:36 PM
  5. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
