    Aha, didn't notice the "plus" range. Okay, one in the post and I'm going to try a LinuxCNC / parallel-port install.
    If you'd like I'd be happy to try installing UCCNC in demo mode prior to the linux install, to understand any installation issues, though with the licensing I don't think I'll be able to drive my mill directly - but I think if the demo works then it should be just about there.
    They give you rather more room to fit an HDD and if you wanted to run LinuxCNC using one of the Mesa controllers that has a PCI card, then there's room for that as well. However I suspect with a suitable compact operating system (i.e. not full Windoze 8/10) and using the machine purely for running the CNC, a 16GB flash DOM would likely suffice.
    That would be cool, thanks.
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I used to run my Warco on a 8GB DOM using linuxcnc I still run it on the lathe. plugged into a small MB. I am following this thread with interest
    If you're looking to put Linux on a thin client PC, then there's quite a bit of useful info. here:
    https://www.parkytowers.me.uk/thin/
    ... just wish I had the time to properly learn a new OS
    Just wish I had the available memory to properly learn ANY OS!
    Glad you got your thread back, but it's been a very informative exchange.
    Kit
    Dammit!, the box is literally straight from a (corporate) install - it's trying to logon to their CE network servers, prompting for login/password credentials. I don't think I'm going to be able to pull anything together re. a Win7CE install.
    Does it seem to be running Windoze? if so you might be get round it by logging in as administrator - a quick google should pull up the default password. What you've got seems to be fairly common, there's info. out there for how to get round it and put on a new OS.
  1. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  2. Machining thin Balsa
    By Nthkentman in forum Woodwork Discussion
    Last Post: 05-04-2015, 08:37 PM
  3. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
  4. Replies: 5
    Last Post: 15-04-2012, 12:36 PM
  5. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
