Well, I spent a bit of time looking into that side of things - being a bit perfectionist I wanted to slim down the Windoze Compact Embedded (WCE) as much as possible - but didn't really manage to sort it. It appears you're largely stuck with what you've got, the only way to thoroughly customise it is to create your own WCE image which you then install that can have as few or as many features as you want. To do that requires a development kit, one day if I'm feeling brave and with a lot of time to kill I might just give Microsoft a buzz and find out how you get one, however I can't help but feel it will be expensive
PS there seem to be some 3rd party developers doing development kits which might be worth a look at too. With WCE7 coming to end of life in 2021, there might be something going cheap?
PPS Another thing I discovered is that WCE (unlike NT based versions) is a real time OS.
Yes, with all the chaos of the last few weeks I'd forgotten that - but it was a generous arrangement and I thank you for it.Last edited by Voicecoil; 28-03-2020 at 12:06 PM.
12-04-2022 #2
You can easily do this using Windows. Compatible with DOS applications. Working in a Windows environment does not force you to give up using DOS programs. Moreover, to run DOS programs, as a rule, there is no need to exit Windows. However, DOS programs running Windows are slower. By the way, what I like about Windows is that it is absolutely unpretentious in terms of licenses. You can always find even Windows activation keys. For example, using a website mysoftwarekeys.com . I hope this information will help you.
15-06-2023 #3
I found your write-up on repurposing a thin client PC quite interesting. I totally get the appeal of having a dedicated, compact, and cost-effective controller that doesn't go on vacation for software updates! Personally, I prefer an all-in-one machine for CAD/CAM purposes, considering the space constraints.
Regarding the configuration of embedded systems, I'm not an expert, but I think it would be great if there were a general "config" file that could simplify the process for others. Maybe someone in this forum knows more about it and can offer some insights.
Have you checked out the Reddit sub that discusses various Windows-related topics? They might have some helpful information for you. It's a great community to connect with fellow Windows enthusiasts.Last edited by mra4nostop; 20-06-2023 at 05:57 PM.
Windows 7 ~ Microsoft relents on shorter Windows 7 support decree
By AndyGuid in forum Computer SoftwareReplies: 4Last Post: 15-08-2016, 03:30 PM -
Machining thin Balsa
By Nthkentman in forum Woodwork DiscussionReplies: 3Last Post: 05-04-2015, 08:37 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
Step clamp design - Hold down thin or irregular shaped objects while milling!
By Lee Roberts in forum Programmers CornerReplies: 5Last Post: 15-04-2012, 12:36 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
