    hi i want to have dual steppers on y and z axis. in mach3 i can only see setting for slave for one pair of motors for one axis. anyone no how to get around this.
    thanks
    Maybe use closed loop steppers and simply common up the STEP and DIR inputs to the drivers????
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 3 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    You could change to LinuxCNC v 2.8 but that's a bit drastic!
    I used commoned connections in the past as Voicecoil suggests without any difficulties. The only problem is you don't have any auto-squaring and will have to manually square up the axis if you accidentally turn one of the leadscrews.
    Kit
    thanks guys, if it can be done in linuxcnc i will use that, i can use linux but not used linuxcnc.
    Kitwn's Avatar
    Quote Originally Posted by xadmx View Post
    If you want to go down that route I started a thread last year about installing LinuxCNC and updating to the version that allows auto-racking and setting it up. Clive C is a knowledgable user and added a lot of very useful help.
    You've probably also seen the ongoing discussion about it in the thin clients thread.
    http://www.mycncuk.com/threads/12687...LinuxCNC-v-2-8
    Kit
  1. CSMIO/IP-M and slave axis functionality
    By Neale in forum CS-Lab (CSMIO)
    Last Post: 29-01-2019, 10:33 PM
  2. Slave axis help
    By Duffman in forum Gantry/Router Machines & Building
    Last Post: 24-01-2016, 05:43 PM
  3. Replies: 9
    Last Post: 23-05-2015, 02:07 PM
  4. Home Switches & Slave Axis in Mach 3
    By Tenson in forum Artsoft Mach (3 & 4)
    Last Post: 03-03-2014, 11:43 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
