Thread: 2 + 2 slave axis
10-10-2019 #3
You could change to LinuxCNC v 2.8 but that's a bit drastic!
I used commoned connections in the past as Voicecoil suggests without any difficulties. The only problem is you don't have any auto-squaring and will have to manually square up the axis if you accidentally turn one of the leadscrews.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
CSMIO/IP-M and slave axis functionality
By Neale in forum CS-Lab (CSMIO)Replies: 24Last Post: 29-01-2019, 10:33 PM -
Slave axis help
By Duffman in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 24-01-2016, 05:43 PM -
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
