    EXEL SL6090 Pro CNC Router £5500 ONO
    The machine is in excellent condition and full working order. It has been very well looked after over the last three years. We purchased it new from EXEL for £8100 and have now upgraded to another larger machine from the same manufacturer.
    We have recently had a vacuum bed fitted to the machine that works brilliantly at holding down all kinds of sheet material The Vacuum Table and Pump were supplied by Vacuum Tables UK.
    The machine can comfortably cut Birch Ply, MDF, Hard Wood, aluminium and brass
    Features:
    Working Area - 900mm x 600mm x 100mm
    Vacuum Bed - 900mm x 600mm x 100mm
    Weight - 200kg
    Axis Travels - X (605mm) Y (905mm) Z (195mm)
    Overall Dimensions - 1500mm high x 1300 long x 880mm wide
    Max Rapid Speed - 6000mm/min
    Max Working Speed - 4000mm/min
    Accuracy/repeatability - 0.05mm (0.002")
    Power Supply - 230v AC / 1 phase
    Ballscrews- 16mm x 5mm on Z, 16mm x 10mm pitch on X and Y
    Controller - Handheld jog pendant, USB data transfer
    Spindle - ELTE 2400 watt ER25
    Motors - 3.1Nm nema 23
    Base frame - powder coated steel, double adjustable damping feet
    Available now in central Brighton (next to New England House), please get in touch if you would like to view or have any questions
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  5. FOR SALE: Exel HD1013 heavy duty CNC router
    By Deuce_Coupe in forum Items For Sale
    Last Post: 04-06-2014, 01:50 PM
