Thread: Time to share
    Hi.
    I'm working on this machine for a while now.
    dimensions:
    legth 100cm, width 85cm(motor to motor) 65cm inside of the uprights.
    working area 450x700x200mm(X Y Z)
    from above quick render i have done:
    Gantry, Z plate and base welded + stress relieved.
    Z plate and gantry machined to 0.01mm, or should I say: I cant see any twist or bow in them.
    Base machined to +-0.1mm, got fed up with machining company and decided to go for epoxy self level cast. I woud scrape it in, but i can't afford surface table big enough to give me reliable reference for this size. I have 600x400mm one i can see/masure twistand dip in my base rail supports.
    Gantry and base uprights will be filled with epoxy concrete for reinforcement and dampening purposes.
    So far i learned that:
    "precision" engineering companies in my area can't measure 0.1mm bow in 1000mm and 800mm long parts and can't machine them flatter than 0.1mm.
    What is mystery to me is why they have gigantic granite surface table in their inspection room.
    Hand scraping is loooong process but works.
    Photos to come soon.
    Epoxy casting is bullshit.
    Looks brilliant, even quick check with straight edge looked promising.
    But check it with dial indicator and mallet+chisel is your next tool.
    Luckily it's only 440g of epoxy and 2 days wasted.
    You forgot the pics
    You forgot the pics
    Yes, too pissed off by wasted time, sorry
    Quote Originally Posted by Sasquatch View Post
    Yep. Been there. Not to mention the wasted money. But keep at it :)
    If its worth anything, my second pour went a LOT better. They're within +/- 0.05mm immediately after the pour, and its a nice smooth deviation so easily shimmed. You have to be very careful with the type of epoxy and the method of the pour - but theres lots of info and videos on here if you look carefully.
    Big problem with pouring is that I already have holes drilled and tapped. PVC hose on screw, greased and threaded in keeps threads safe but disturbs surface.
    My mistake, taken machine shop word for flatness and drilled before checking.
    Today chiselled off all poxy epoxy and made map of unevenness.
    Two opposite corners are 0.1 and 0.35 mm high.
    Remaining 700mm and 600mm of each rail are within 0.02mm, easy to scrape in.
    Good news is I got my money back for machining.
    Plan for big deviance is to use dremel with carbide burr to speed things up, one cross pass takes 0.05 off. Take it to within 0.05 with burr then continue by hand proper way. 20-30h should be enough.
    Base cleaned up and ready for scraping:
    Hi Sasquatch
    You gave up too early. Look what the world is doing.
    https://www.google.com/search?q=epox...%3Apinterest.*
    https://www.google.com/search?rlz=1C...4dUDCAc&uact=5
    Regards
    John
    John, I think you misunderstood. I gave up on pourig unfilled epoxy to level uot linear rails supports.
    I would love to build my router entirely out of epoxy granite. Unfortunately getting aggregates in less than tonne per grade and lack of big enough flat surface to cast against pushed me towards steel.
    I'm still filling sections with epoxy granite but with aggregate far from optimal, mostly as dampening medium. Also hollow 100x50x4mm gets easily crushed when bolted together. Gantry beam is filled with epoxy granite to stop this. Gantry will be bolted with 4 m8 bolts at each side.
    Also if(and mostlikely will) my Z axis proves too flimsy to give reasonable aluminium cut finish it will get cast epoxy granite upgrade. But that's distant future.
    As for works update :
    Scraping done to within +0.05mm.
    Gantry beam is granited up
    Tomorrow hand scraper will get workout.
    Update,
    Decided to order proper straight edge, HELIOS-PREISSER 0464103 Stahllineal DIN 874/0, 1000 mm. Straight and parallel to 0.012mm
    Came today, wrapped in cardboard with massive dent 200mm from end. Dropped it on granite surface plate -> 0.03 mm feeler gauge fits under, clearly bent.
    Sent it straight back(pun intended).
    Good in a way, laser+camera alignment works out much cheaper and as far as i can say just as accurate.
    Z axis greasing extensions
  1. NEW MEMBER: Long time lurker, first time poster.
    By MatB in forum New Member Introductions
    Last Post: 18-02-2019, 05:49 PM
  2. Share some PCB design sites which may be helpful
    By Vicos in forum General Electronics
    Last Post: 22-08-2016, 08:10 AM
  3. NEW MEMBER: Hello - Keen To Share and Learn
    By dodo in forum New Member Introductions
    Last Post: 20-02-2013, 12:09 AM
