Thread: Time to share
Hi Sasquatch
You gave up too early. Look what the world is doing.
https://www.google.com/search?q=epox...%3Apinterest.*
https://www.google.com/search?rlz=1C...4dUDCAc&uact=5
Regards
John
13-10-2019 #2
John, I think you misunderstood. I gave up on pourig unfilled epoxy to level uot linear rails supports.
I would love to build my router entirely out of epoxy granite. Unfortunately getting aggregates in less than tonne per grade and lack of big enough flat surface to cast against pushed me towards steel.
I'm still filling sections with epoxy granite but with aggregate far from optimal, mostly as dampening medium. Also hollow 100x50x4mm gets easily crushed when bolted together. Gantry beam is filled with epoxy granite to stop this. Gantry will be bolted with 4 m8 bolts at each side.
Also if(and mostlikely will) my Z axis proves too flimsy to give reasonable aluminium cut finish it will get cast epoxy granite upgrade. But that's distant future.
As for works update :
Scraping done to within +0.05mm.
Gantry beam is granited up
Tomorrow hand scraper will get workout.Last edited by Sasquatch; 13-10-2019 at 05:37 PM.
NEW MEMBER: Long time lurker, first time poster.
By MatB in forum New Member IntroductionsReplies: 1Last Post: 18-02-2019, 05:49 PM -
Share some PCB design sites which may be helpful
By Vicos in forum General ElectronicsReplies: 0Last Post: 22-08-2016, 08:10 AM -
NEW MEMBER: Hello - Keen To Share and Learn
By dodo in forum New Member IntroductionsReplies: 5Last Post: 20-02-2013, 12:09 AM
