Hi - Anyone found a good Chinese source for 6&8mm Downcut 2 flute carbide end mills for wood routing. Alibaba and Bangood do not seme to recognise the term "downcut". Or should I be using another search term? Most grateful for your experienced advice.
12-10-2019 #2
Compression bit
12-10-2019 #3
May have found a possible source on Alibaba, Waiting for quotes with shipping cost. Will report back.
12-10-2019 #4
12-10-2019 #5
My existing one`s are constant flue angle.
12-10-2019 #6
Downcut bits are very useful. Can be harder to find.
Saite_cutter store on AliExpress sells some downcut bits. Also known as left hand bits.
Store Information
https://s.click.aliexpress.com/e/mW45b6SG
AU $28.64 9%OFF | 2Pcs 6x25mm Down Cutter Left hand Spiral Bit CNC Router Tool AAA Series One Flute acrylic Aluminum carving frezer endmill
https://s.click.aliexpress.com/e/tuaU3ggC
13-10-2019 #7
Thanks pippin88. - Just ordered from Saite_cutter store on AliExpress. Just what I was looking for. Appreciate the heads up.
Where to source HHS Downcut end mills?
By cncJim in forum General DiscussionReplies: 8Last Post: 22-02-2016, 02:39 PM -
FOR SALE: ITC 3051 10mm 3 Flute Long Length Carbide Ali End Mills
By Caster1 in forum Items For SaleReplies: 0Last Post: 05-01-2016, 12:21 AM -
WANTED: 1/8" or 3mm Single flute carbide cutters
By craigrobbo in forum Items WantedReplies: 7Last Post: 09-04-2013, 06:49 PM -
4mm Carbide Cutters Single Flute?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 07:52 AM -
By Jonathan in forum Tool & Tooling TechnologyReplies: 52Last Post: 11-11-2011, 06:48 PM
